fuel lines touching hot egr = bad.
So leave it then
Is there any particular reason for oil covering the bolts when I removed the lift points? I wouldn't think they'd go that deep.
LIM bolts?
The bolt holes are open to the head/rocker cavity.
I put the bolt back in, I'll have to remember to go back and coat the threads before they fall out. I just left the nuts off the bolts that were coming from the motor.
It wasn't pouring oil or anything, the threads just had oil on them, as did the bracket where the bolt had been.
Well, first is a fuel line fix so I'm not spraying fuel at my rear valve cover anymore, then headers to fix my leaky manifold. I'd like to get polished aluminum valve covers, but they're a bit out of my current budget with all the other fixes.
Disable the codes.
I know it throws a code, but would there be any effect on the engine? I still have the stock PCM and no tuner.
Okay, but wish me luck finding anyone local with a tuner![]()
On the lift bracket bolts. The only way they can be oily is a leaking valve cover gasket. Or a previous leaking cover gasket. No need to put those bolts back in or coat them. They are extras if the lift brackets are off.
Do you have any state emission inspections in KY? Years ago when I worked for an emission testing company we did have some areas of KY. If so.. they may do a visual check for the emissions equipment aka EGR.
Likely I was the only intercooled guy to still have an EGR on my car.Always passed inspection too.
No testing here, I was just worried about the ECM flipping out because something was missing.
As far as valve cover leak; there's thick gunk all around the front gasket, not as bad in the back, but there is a small leak on the drivers side. There's some orange rubber sticking out there and a bit of fresh oil.
Nope..that likely means you are building pressure in the covers, which points to a bad or incorrectly installed pcv. At least that's the experience I've had.
Looks fine as far as I can tell, not that that really says anything. How can I check to be sure?
Also, I'm fairly convinced at this point that the mechanic the salesman used before I bought the car was an idiot, and both valve covers and the UIM have been replaced. Is there a chance he just mucked up the gasket on the install?
-Checked it again. It's not flowing oil, and when I wipe it it stays dry for several days, but the shredded gasket does spread the length of the rear valve cover, not just the one spot as I had thought.
