I know I already asked a question about nitrous but my friend had a dry kit so I didnt go through with the whole nitrous setup. But anyway I just found a Nitrous Express kit 20927 and was wondering if it would work on a stock 06 l26?
Yes, but let me suggest an alternative for its cheap awesomeness that works well:
Universal Wet Nitrous oxide kit for cars and trucks. Nitrous system for all use with EFI cars and trucks. Our Nitrous Oxide system will add that extra boost needed. Buy Nitrous oxide direct from the manufacturer. - Universal Wet Nitrous oxide kit for
Dont forget you will need to purchase a TB spacer to tap and drill for the shark nozzle to spray after the MAF.
Thx for the quick reply, I would defiantly not be buying this kit for 1200$ lol. The reason I asked about this kit was because it was Nitrous Express (heard it was supposed to be the best of the best) and I found it for $600. I personally thought this was a steal.
I guess a TB spacer is added to the list lol.
Can I also run the NEX kit with just a single shark nozzle? Im asking because its supposed to be a "dual stage" kit.
TX, can you not just tap the intake tube post MAF instead of running a N2o TB spacer?
I'm always one of those "don't wanna run TB spacers on 3800" kinda guys.
I don't see why you couldn't, but I'd only run a single stage. Dual stage is probably more than what you are looking for.
Will you be using a WOT switch, push button, or window switch to spray?
You won't be able to feel a 50 shot and 75 shot you will barely feel. For the most umpf in the butt dyno go with at least 100 shot.
You could. The only reason I said TB spacer is just because it makes for putting the kit on/off off your car simple. In that I mean there's no holes you have to cover back up when reverting back to stock.
NX stuff hits like a train, particularly the Twin Gemini MAF kif for LSx. There's a reason their stuff costs more.
