Thread: Catalytic Converter HELP!!!!!!
Results 1 to 19 of 19
  1. #1 Catalytic Converter HELP!!!!!!
    Stockbridge
    I know my Catalytic converter is going out because it smells like rotten eggs when i get on the pedal. How hard is it to do and How much would a shop charge?
  2. #2 Re: Catalytic Converter HELP!!!!!!
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    Easy. And they wont charge anything. Because you're gonna cut it out and install one of ZZP's downstream O2 sensor simulators.
    Or at least that's my suggestion.
    The evil LG8 still refuses to die.
  3. #3 Re: Catalytic Converter HELP!!!!!!
    What year? Because, anything '01+ you can't put an o2 simulator in there and not **** with the cat diagnostics in the PCM. You can get a universal high flow converter from Magnaflow off of EBay for like 50 bucks...and a shop would probably charge like 10-20 bucks to cut out the old one and weld in the new one.
    Keep in mind, unless it is a factory unit, most of the time it'll still trip the SES light for a catalyst since it flows better than stock.
  4. #4 Re: Catalytic Converter HELP!!!!!!
    Stockbridge
    Will they cut the cat out or replace it? Its a 06 so i still have to pass emissions.
  5. #5 Re: Catalytic Converter HELP!!!!!!
    Just buy a 3" catted downpipe from ZZPerformance and have an exhaust shop bolt it in there for you if you don't have the means to install it yourself.
    ZZPerformance - Go Fast... Not Broke | 3800 | Ecotec | Sonic/Cruze
    Exhaust section...drop down for the cheapest, catted one.
  6. #6 Re: Catalytic Converter HELP!!!!!!
    Stockbridge
    ima check it out. im goin to the shop later to see what they say. i just dont wanna spend 300$ on a cat.
  7. #7 Re: Catalytic Converter HELP!!!!!!
    Considering ZZP's catted 3" one not only gives you better performance and MPG's, but it's at least a hundred bucks less.
  8. #8 Re: Catalytic Converter HELP!!!!!!
    Stockbridge
    I got a hookup at a shop so ima see which one will be cheaper getting a universal or doing the zzp method.
  9. #9 Re: Catalytic Converter HELP!!!!!!
    Well, a universal welded into the stock DP would be cheaper, but it'd probably be cost effective down the road, especially with gas prices on the rise to help those MPG's out. I noticed a few more MPG's easily going from a totally stock exhaust to my 3" downpipe/3" catback setup.
  10. #10 Re: Catalytic Converter HELP!!!!!!
    Stockbridge
    One more? on the zzp downpipe. should my exhaust size be 2.5" or 3. Its a 06 Grand Prix Base.
  11. #11 Re: Catalytic Converter HELP!!!!!!
    2.5" or 3" will work, it's all bolt in.
  12. #12 Re: Catalytic Converter HELP!!!!!!
    Stockbridge
    Is there a diffrence in performance out of the 2 sizes?
  13. #13 Re: Catalytic Converter HELP!!!!!!
    Nothing that you wouldn't really be able to see unless you had the car strapped to a dyno in my opinion.
  14. #14 Re: Catalytic Converter HELP!!!!!!
    Stockbridge
    Alright. Im gonna go with the zzp. Thank you so much for the help.
  15. #15 Re: Catalytic Converter HELP!!!!!!
    No problem.
  16. #16 Re: Catalytic Converter HELP!!!!!!
    Keep in mind..the ZZP pipe will likely set the engine codes as well.
  17. #17 Re: Catalytic Converter HELP!!!!!!
    For once,
    I actually covered it LOL
  18. #18 Re: Catalytic Converter HELP!!!!!!
    Stockbridge
    yea it still cheaper. the shop priced me 273$ ill get the zzp and live ses light
  19. #19 Re: Catalytic Converter HELP!!!!!!
    For once,
    I was merely reiterating.
  1. catalytic converter CEL, how to replace catalytic converter
    By scha0786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2012, 11:53 PM
  2. catalytic converter
    By c002529 in forum General Tech Discussion
    Last Post: 10-07-2010, 11:45 AM
  3. Catalytic Converter
    By LonelyLoser45 in forum General Tech Discussion
    Last Post: 04-17-2009, 12:24 PM
  4. I need to no were i can get a catalytic converter.
    By krazyog1 in forum General Tech Discussion
    Last Post: 03-03-2009, 02:00 PM
  5. Catalytic converter?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2008, 07:56 PM
