Hey my mother 2000 3800 Camaro is using coolant. I am pretty sure it's the coolant elbows. That being said. How is the easiest way to fix it? The upper intake manifold is under the fire wall. Can I pull the water pump or the heater core idle bracket thing and install the elbow that way?
Here are a few pics:
The first pic is the elbow that goest from the LIM to the alt idler bracket.
The second pic is the lower side of the idler bracket just above another idle pulley infront of the head.
