Thread: Just bought an '05 with 100K that needs a new engine
Results 1 to 9 of 9
  1. #1 Just bought an '05 with 100K that needs a new engine
    SE Level Member woodoggie's Avatar
    KY
    Very noisy main bearings on cold start. I drove it 125 miles home though. I got it for a decent price and i'm going to fix it for my daughter
    I think I will buy a used engine and I'll go through the trans too.
    Whats the best way to pull? engine only, engine and trans, out the top or bottom?
    It's a nice car, so I want it to be a reliable driver for her.
    Thanks for any help!
  2. #2 Re: Just bought an '05 with 100K that needs a new engine
    GT Level Member TeeWX's Avatar
    Apr 2009
    Cresco, Iowa
    If you have a cherry picker it's really not that bad to pull it out through the top. That's what I've always done anyways. I always leave the trans in the car. A used engine is pretty much your only real choice. It's not cost effective to rebuild a 3800 at this point.
    1998 GTP : XP Cam, 3.2 Pulley, Supporting Mods<Sold>
    2001 Formula M6 : Shhhh
    2001 SSEi : New DD, Bone Stock for now
  3. #3 Re: Just bought an '05 with 100K that needs a new engine
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Engine out the top. Leave the transmission in there. Very simple.
  4. #4 Re: Just bought an '05 with 100K that needs a new engine
    Does it actually knock?? Like metal in the oil?
    It could just be very loud lifters are cold start up. If the noise goes away when warm and the "knock" does not increase with rpms, it may not be bottom end related at all.
  5. #5 Re: Just bought an '05 with 100K that needs a new engine
    KY
    Trust me, it knocks, I've heard that music before!!
  6. #6 Re: Just bought an '05 with 100K that needs a new engine
    Okay lol.
    Well just find a motor thats the same as yours and go to town.
  7. #7 Re: Just bought an '05 with 100K that needs a new engine
    Meh, get an L36...the '97-'03 N/A bottom end. I'd like to think the rods are way better than the popsickle stick L26 rods in that car you got.
    You can swap over all the stuff from the '05 to the older short block.
    Trans wise?
    When the motor is out...drop the pan, wipe it clean, same with the magnet in there, toss in a new filter (gasket should be reusable) and refill with Dex 6 minus about a quart of stop slip from Lucas.
    Should be golden.
  8. #8 Re: Just bought an '05 with 100K that needs a new engine
    Kansas
    To add onto what bluegtp91 stated, a '97-'03 bottom end will also be cheaper budget wise. Still a good bottom, and has better con rods. And some Lucas in the tranny is a good additive.
  9. #9 Re: Just bought an '05 with 100K that needs a new engine
    If you only plan to yank the engine, out the top by itself. If you are going to go through the trans like you said, take both at once. I find it pretty easy with a leveler and unbolting the MC from the booster (leaving it connected to the flex hoses and moving it a little for clearance.
    Once the assembly is off the mounts, bring the passenger side up all the way and you should be able to guide it out relatively easy. FWIW I do them by myself.
  1. 100k mile mark... things to check/replace?
    By shart in forum General Tech Discussion
    Last Post: 10-17-2011, 12:26 PM
  2. So if you had 100k..
    By RegorHtims in forum Off Topic Discussion
    Last Post: 09-14-2011, 11:44 PM
  3. Hello All - 05 GTP just hit 100K
    By KB8URR in forum Introductions/Noob Questions
    Last Post: 02-21-2011, 08:50 PM
  4. Cheap modded 97 Grand prix around 100k only $2,500
    By ls6velless454 in forum Midwest
    Last Post: 02-16-2010, 05:16 PM
