Thread: All headers leak?
Results 1 to 10 of 10
  1. #1 All headers leak?
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    I have everything for a top swap and PEMS but I want to be safe and go with the standard pulley and headers. This is my daily driver and I drive more than 400 miles per week often more far from home. Is there a set of headers that will last for the life of the car and not leak? I don't want to be gooping RTV every six months and worrying about something cracking. It seems like every thread on headers involves RTV parties, I have the original short block and maybe I'll just freshen it up and use it with the PEMS. Thanks in advance.
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  2. #2 Re: All headers leak?
    Ohio
    get sd's...have the flex section fixed. make sure the studs come out of the heads. your good
  3. #3 Re: All headers leak?
  4. #4 Re: All headers leak?
    Canterbury, CT
    Quote Originally Posted by 99pgpgt View Post
    Thank you both, is there a thread with this fix?
  5. #5 Re: All headers leak?
    Ohio
    no, just take the rear header to an exhaust shop and have them cut the flex in it out and weld a good one in
  6. #6 Re: All headers leak?
    Feb 2008
    I'd get speed daddys if you wanna keep price down. Get ZZP's flex pipe and weld it in instead of the one it has.
    If you want to spend a little more, TOGs are usually a safe bet.
  7. #7 Re: All headers leak?
    Vancouver, WA
    With Speed Daddy's, just make sure you use band clamps and Accuseal clamps, not the crap ones they come with.
    Slowest 'Cooled Gen V ever
  8. #8 Re: All headers leak?
    Omaha, NE
    Better than clamps, have your headers welded. I bought my pacesetters pre welded, and I don't have any header leaks.
  9. #9 Re: All headers leak?
    I don't use RTV when installing headers. If you read posts by me, you'll see I dislike the mention of doing it. Get clamps from FrozenBoost.com instead of the ones they give you and one trick.. when putting the crossover/front on, leave the cross over loose and tap the headers at the front/crossover connection area as you tighten the bolts for the front. That'll seat things nicely.
    I don't accept leaks from headers. There's no reason to.
  10. #10 Re: All headers leak?
    Vancouver, WA
    Are the clamps from FrozenBoost that you're talking about the T bolts? If so I'm not a fan, the Accuseal clamps worked much better for me.
  1. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  2. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  3. new headers now vacuum leak
    By copperpacecar in forum General Tech Discussion
    Last Post: 06-14-2010, 09:53 PM
  4. Oil leak exhaust headers
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2009, 08:33 AM
  5. XS Power Headers Vs. SSAC Headers
    By 04CompG in forum General Tech Discussion
    Last Post: 12-02-2008, 01:12 PM
