Thread: MAF killer
Results 1 to 4 of 4
  1. #1 MAF killer
    May 2011
    Bremen,GA
    Does anyone have an idea as to why my 97 GT keeps killing the MAF?
    I just installed a new one from Borg Warner last week and it's already
    throwing a PO102,the engine was dying right after start-up when I
    installed the new MAF in the parts store parking lot.
    Sometimes unplugging and starting will allow idle,have had it die when
    plugged in after start and had it run at other times.
    Jan 2009
    Tallahassee, FL
    I'd start looking at your wiring/grounds if you have the same problem after a new sensor. Also I don't know what values, but check to see if the right voltage, etc is getting to the sensor, I'm sure someoneon here should know what they should be.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: MAF killer
    I'd check wiring as well. Being over the exhaust, I've heard of a few guys finding pins backed out, wires hard and crumbling which led to issues etc
  4. #4 Re: MAF killer
    May 2011
    Bremen,GA
    Thanks guys.
    I just heard that the IAC function could also cause the MAF to have issues,but my IAC and TB are spotless.
  1. i am the bird KILLER!!
    By Pkorn in forum Off Topic Discussion
    Last Post: 08-02-2011, 09:11 PM
  2. Im the route 120 killer
    By GTPJOE90 in forum Track Sessions and Kills
    Last Post: 03-05-2009, 05:31 PM
  3. killer kill
    By arj124 in forum Track Sessions and Kills
    Last Post: 10-23-2008, 01:25 AM
  4. gtp=honda killer
    By gtpinsc in forum Track Sessions and Kills
    Last Post: 09-02-2008, 12:24 AM
