Thread: Check engine light on! Any suggestions?
Results 1 to 4 of 4
  1. #1 Check engine light on! Any suggestions?
    SE Level Member Grand Prix Chick's Avatar
    Oct 2011
    Atlanta, GA
    I'm sure there is a thread on this already but I can't seem to locate it so sorry. I have a 2001 GP GT 3800. My check engine light is on. I had a diagnostic done and the codes I got were:
    - P0102 Mass or Volume air flow circuit low input
    - P0443 EVAP emissin control system purge control valve circuit
    - P0135 O2 sensor Bank 1 Sensor 1
    - P0141 O2 sensor Bank 1 Sensor 2
    I have changed both O2 sensors and the MAF sensor. The light was reset and stayed off for about 20 miles then came right back on. I had a diagnostic done again and it's still the P0102 and P0443. Any suggestions on how I can fix this problem being as though I have replace the MAF?
    Thanks in advance!
  2. #2 Re: Check engine light on! Any suggestions?
    Jan 2012
    FT Campbell, KY
    The evap is normally something as simple as the gas cap being loose. If your O2s are still triggering, it COULD be a bad cat. Is the car hesitating or not performing at all? The MAF...clueless. I'm not sure what it all means in context, sorry.
    Colleen
    : CAI, HV3, 2.5" d/p w/h/f cat. Full suspension, PowerSlots w/Hawk HPS, GR2s, Sonar projectors. Needs tune. Awaiting install of FBod brakes.
    Shianne: 98 L36 MM5. Good start to a LONG project.
  3. #3 Re: Check engine light on! Any suggestions?
    GT Level Member Brian99SE's Avatar
    Dec 2011
    Cadiz, Ky
    The purge Control valve is in the engine bay, near the intake if i remember right. It has a Line running from the tank To the Valve, To the intake. It allows the engine to burn fuel vapors building up in the tank.
    99 Grand Prix SE-Blue CAI, 3.03 GR Transmission, U Bend Delete.
    time to call the exterminator
  4. #4 Re: Check engine light on! Any suggestions?
    Sep 2011
    MI
    Trouble code P0102.
    1. With the engine running, backprobe the Mass Air Flow (MAF) sensor. Check for ignition power on the Pink and 0 volts (ground) on the Black/White.
    2. If OK, check the frequency (Hz) on the Yellow wire. A normal reading is about 2,000 Hz at idle, rising to about 10,000 Hz at Wide Open Throttle (WOT).
    3. If lower than specification, or erratic, disconnect the MAF sensor and verify there is 5 volts reference from the Powertrain Control Module (PCM) on the Yellow wire.
    4. If OK, replace the MAF sensor.
    5. If there is 0 volts on the Yellow wire, check for a bad wire to the PCM. If the wiring is OK, replace the PCM.
    -I take no credit for this info it was originaly posted by a fella named Kevin-
  1. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  2. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  3. Check Engine Light
    By lemmy33 in forum General Tech Discussion
    Last Post: 11-03-2011, 04:10 PM
  4. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 10-08-2008, 10:31 PM
  5. Check engine light on
    By darkwingduck in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-18-2008, 07:59 PM
