Thread: Reset Check Engine Light
Results 1 to 5 of 5
  1. #1 Reset Check Engine Light
    Apr 2011
    Ohio
    Hey, guys. My "Check Engine Soon" light is on steadily (not flashing). I know 100% that it's just an Evap emissions code. I've had this happen like 7 times already on this 2003 GP GT. I have always just taken it to the shop to have them read it with their OBD computer and it's the same thing every time: "Did you put the gas cap on right?" I'm sick of going to these guys and bugging them with this stupid evap code, and was wondering if there's any way to reset the light without doing it through the OBD port or unplugging the battery.
  2. #2 Re: Reset Check Engine Light
    SWPA
    Those are your choices. Go to Advance or Auto Zone. The read and reset codes for free.
  3. #3 Re: Reset Check Engine Light
    GTP Level Member
    Oct 2011
    Raleigh, NC
    You can get a cheap code reader on Amazon/ Ebay for $25 - $30 and do it yourself.
    Or fix it even ?
    1997 Red GTP 182000 miles stock
  4. #4 Re: Reset Check Engine Light
    GT Level Member Brian99SE's Avatar
    Dec 2011
    Cadiz, Ky
    You can erease your codes pretty easily...
    1, Go to your car. Stick key in the door.
    2. Lock and Unlock Repeatedly.
    3. Repeat 5 Times.
    4. Get in the Car.
    5. Roll Windows down
    6. Turn Key on
    7. Turn key to Accessory.
    8. Turn Key back to ON
    9. Turn Hazards on.
    10. Depress the Gas Pedal 3 Times Pausing one second between Presses.
    11. Stare at the Gauge Cluster Grip the Steering wheel Firmly
    12.Turn Steering wheel 1/4 turn LEFT And RIGHT (ECU reads clock spring rotations through SRS Airbag module)
    13. Repeat Step 12 and Make Really, Really Loud RACEKAR noises....
    Or purchase a Cheap Scantool. Walmart used to carry a cheap model for around 50 $
    Or Amazon, This http://www.amazon.com/Autel-MaxiScan...5732475&sr=8-2
    99 Grand Prix SE-Blue CAI, 3.03 GR Transmission, U Bend Delete.
    time to call the exterminator
  5. #5 Re: Reset Check Engine Light
    Dec 2011
    Cadiz, Ky
    NVM
  1. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  2. Reset Check Engine Light
    By barbschwartzer in forum Engine
    Last Post: 01-07-2012, 04:26 PM
  3. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  4. Reset Check Engine Soon Light
    By maingate3133 in forum Introductions/Noob Questions
    Last Post: 08-12-2009, 09:11 PM
  5. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 10-08-2008, 10:31 PM
