Thread: Speed Daddy headers
Results 1 to 20 of 24
  1. #1 Speed Daddy headers
    SE Level Member RedGrandprixgt53's Avatar
    Oct 2011
    Kenosha, WI
    I was looking into getting headers, and I wanted to know if speed daddy headers leaked cause i heard the pacetters leak and i dont wanna spend an arm or a leg for it
  2. #2 Re: Speed Daddy headers
  3. #3 Re: Speed Daddy headers
    St. Cloud, MN
    The flex will more than likely leak. Get a zzp flex to fix that.
  4. #4 Re: Speed Daddy headers
    mine don't leak.....much
  5. #5 Re: Speed Daddy headers
    Grand Rapids, MI
    Quote Originally Posted by DreadMcLaren View Post
    this. my speed daddys are great except the flex is a leaky whore. definitely get one from zzp and fix it before you install it. and you'll thank yourself later.
  6. #6 Re: Speed Daddy headers
    Oct 2011
    Kenosha, WI
    how does it go in like just over it or snap in place? and just the 14 dollar place on zzp? wanna be right before i order
  7. #7 Re: Speed Daddy headers
    The one in my hand is the 3in ZZP flex, buy that and weld it in the same spot. You can see the difference, the ZZP flex is doubled walled and wont blow out and leak.
  8. #8 Re: Speed Daddy headers
    Grand Rapids, MI
    or in my case leak right out of the box
  9. #9 Re: Speed Daddy headers
    Oct 2011
    Kenosha, WI
    Thanks man, great info. This really helps
  10. #10 Re: Speed Daddy headers
    Waukesha, WI
    or header wrap the flex like a i did.
    muffled leak
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  11. #11 Re: Speed Daddy headers
    Bunnell, FL
    i hit way to much stuff w/ my crappy sd ubend and i blew out the flex
    so if i cared i'd get it fixed soon, but may have to wait on the wideband to do it
    I'm a Sex Offender
  12. #12 Re: Speed Daddy headers
    Grand Rapids, MI
    Quote Originally Posted by redlinepontiac View Post
    i thought about that actually. but i've also heard that the flex can collapse internally and cause flow issues so i figured replacing it was the only thing to do really.
  13. #13 Re: Speed Daddy headers
    Speed daddy and pacesetters are not the same design. Pacesetters use a flange at the front crossover, have dual pipes feeding the downpipe/y etc and overall are located in areas that are harder to get into. Speed daddy's with some better exhaust clamps are rather good.
    They don't necessarily leak at the flex. The flex is a cheap thin wall. This was also found on the SLP headers. Replacing it before you install them or wrapping it with header wrap will quiet it down and make them nicer overall.
    The one thing I dislike about them is the location of the O2 bung in the rear header. It requires you to either relocate it or dent the firewall for clearnace.
  14. #14 Re: Speed Daddy headers
    Florida
    yeah i didnt realize about the O2 being so oddly placed.... i had to cut out my firewall anyway to make room for headers... i wish i would have seen that when i was doing the cutting and pounding. but oh well... have another O2 bung down low and my new cat has another bung for when i get the wideband put back in.
    i love my SD headers. even with my car lowered i havent hit anything. so the ubend isnt as bad as some people say. mine has a leak... but its myfault and i just dont feel like fixing it yet. i have the take it all apart in a few weeks anyway to do the topswap so figured 1 month of a leak is livable.
  15. #15 Re: Speed Daddy headers
    Donating Users
    GRAND RAPIDS, MI
    My Speed Daddys never leaked even after hitting the u bend a few times maybe I was just lucky. If I had to install another set I would buy the ZZP flex and install it at the same time as the headers just to be safe.
    2000 Grand Prix SE: Knocking rod mod and broken timing chain mod. L67 coming soon!
  16. #16 Re: Speed Daddy headers
    I hit so much **** with my downpipe I punched a hole in it.
  17. #17 Re: Speed Daddy headers
    May 2008
    Winnipeg, MB
    are the speed daddy headers only for supercharged cars?
    2007 Pontiac Grand Prix
  18. #18 Re: Speed Daddy headers
    GT Level Member 2000GrandPrixGT2000's Avatar
    Trevose, PA
    You can use them on the N/A grand prixs but I have been told that you will lose some low end torque
    I purchased them for my 2000 gt but haven't installed them... might just wait until I get a supercharged engine to really use it to its full advantage
    2000 Grand Prix GT- DIY Spectre HAI, KYB GR-2 Struts, GMPP Front and Rear Sway Bars, GMPP Front and Rear Strut Tower Braces w/ Don Rome Brackets
    Soon to be Installed: Poly Bushings + Poly End Links- Front and Rear GMPP Sway Bars
  19. #19 Re: Speed Daddy headers
    Grand Rapids, MI
    you will lose low end torque without a doubt. i lost it on my gtp even (i live in a big city) and it was quite a bit to notice. now that i've pullied down the torque is more than it ever was so it doesn't matter.
    but yeah. just keep that in mind. it spreads the powerband out instead of it being concentrated on the lower end with the stock manis.
  20. #20 Re: Speed Daddy headers
    Oct 2011
    Kenosha, WI
    well i plan on supercharging it, just putting parts together slowly.
  1. speed daddy headers
    By redlinepontiac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2011, 07:54 PM
  2. speed daddy headers
    By sic40th in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 05:07 PM
  3. Speed Daddy Headers
    By lflylow in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2010, 12:33 PM
  4. Speed Daddy Headers
    By Advan22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2010, 12:06 AM
  5. Speed Daddy Headers
    By Vioarr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2010, 03:29 PM
