tell them you have a GTP.
Magically it'll be listed.
If you used a gasket and it's still leaking that usually is either a cracked t stat housing (which I haven't ever seen) or a need to clean the gasket surfaces better.
I'd say it's more likely a dirty gasket surface. That's my typical experience when someone says it's leakin
Thanks Matt for the edit. My phones browser would not allow it
To the OP here is the stuff to use after you cleaned the surfaces
http://www.permatex.com/products/aut...sket_Maker.htm
