Thread: Thermostat housing gaskets
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: Thermostat housing gaskets
    tell them you have a GTP.
    Magically it'll be listed.
  2. #22 Re: Thermostat housing gaskets
    SE Level Member Fritcr's Avatar
    Apr 2008
    Oh they found the gasket...had to look it up under thermostat housing gasket. But it still leaks.
  3. #23 Re: Thermostat housing gaskets
    If you used a gasket and it's still leaking that usually is either a cracked t stat housing (which I haven't ever seen) or a need to clean the gasket surfaces better.
  4. #24 Re: Thermostat housing gaskets
    Ohio
    use rtv
  5. #25 Re: Thermostat housing gaskets
    Quote Originally Posted by Moar Cats In Muh Trailer View Post
    use rtv
    affffter you clean that gasket surface
  6. #26 Re: Thermostat housing gaskets
    Ohio
    lol exactly
  7. #27 Re: Thermostat housing gaskets
    Apr 2008
    Ok that's my plan for tonight. I will look it over good but don't how I could have cracked the housing. You never know though for sure.
    Thanks much guys!
  8. #28 Re: Thermostat housing gaskets
    I'd say it's more likely a dirty gasket surface. That's my typical experience when someone says it's leakin
  9. #29 Re: Thermostat housing gaskets
    Apr 2008
    I'll go get a new gaket today and clean the surfaces good then put some grey rtv on it. Maybe that will do the trick. Never though a T stat replacement would take me 3 tries. argggg
  10. #30 Re: Thermostat housing gaskets
    Buffalo
    Thanks Matt for the edit. My phones browser would not allow it
    To the OP here is the stuff to use after you cleaned the surfaces
    http://www.permatex.com/products/aut...sket_Maker.htm
  1. Thermostat housing sealant?
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2011, 01:02 AM
  2. thermostat housing bolts stripping my sockets..help!!!
    By dmahlikGT in forum General Tech Discussion
    Last Post: 10-16-2010, 03:34 PM
  3. Replies: 8
    Last Post: 10-05-2010, 08:57 PM
  4. Thermostat...
    By TorqueAutoMotiv in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-13-2009, 11:20 PM
