Thread: Changed the CPS, now what?
Results 1 to 6 of 6
  1. #1 Changed the CPS, now what?
    Dec 2011
    West Virginia
    My GT over this past weekend started shutting off while driving and I came to the conclusion it was the crankshaft position sensor. Fixed that but today I was sitting still and the car bogged down and shut off and would not restart. Finally after about 5 minutes I got it to restart and drove it home. What could be my trouble now?
  2. #2 Re: Changed the CPS, now what?
    MO
    What's it dying like? Lack fuel or lack of spark?
    <brandonl2000> LMAO D!!
  3. #3 Re: Changed the CPS, now what?
    GT Level Member thegipper's Avatar
    grafton, wi
    Are you getting any check engine lights?
    Try unplugging the Mass Airflow Sensor when the car is off and turning it back on with it unplugged. If the car runs better and doesn't die, then you have a bad MAF.
    You can try cleaning it with MAF cleaner or get a new one.
    My 02 GT just recently had the same problem and it ended up being the MAF, doesn't guarantee that this is your problem but its a good place to start.
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  4. #4 Re: Changed the CPS, now what?
    Dec 2011
    West Virginia
    Quote Originally Posted by ZR1Vette09 View Post
    It will restart and idle for a second and just quit. Its getting fuel and spark. I just got it in the car and it started right up no problem, the problem always seems to happen when I drive it somewhere and I have to idle it will just quit. I'm going to go unplug the MAF and start it and see how it idles.
  5. #5 Re: Changed the CPS, now what?
    Dec 2011
    West Virginia
    Quote Originally Posted by thegipper View Post
    No check engine light. Just unplugged the MAF and it didn't die but like you said that doesn't mean it is the MAF. It's one of those problems where it won't die in your driveway but will die when you are driving it if you know what I mean.
  6. #6 Re: Changed the CPS, now what?
    Drive with the maf unplugged for a while. Don't beat the car with it unplugged and that'll give you a better test.
  1. L36 Oilpan changed!!
    By mike2pin in forum General Tech Discussion
    Last Post: 11-21-2011, 09:28 PM
  2. LTFTs changed, why?
    By Juanmiguel in forum PCM Tuning
    Last Post: 04-16-2011, 02:38 PM
  3. for those of you that changed. upgraded rad
    By kuntzie in forum General Tech Discussion
    Last Post: 07-04-2010, 09:24 PM
  4. Changed It Up A Bit (New Pics)
    By Dboy23 in forum Off Topic Discussion
    Last Post: 05-12-2010, 03:33 PM
  5. So alot has changed.....
    By GTPJOE90 in forum Visual/Body Modifications
    Last Post: 03-23-2010, 05:27 PM
