Thread: Help on crack heads..need advice on l26 heads
Results 1 to 5 of 5
  1. #1 Help on crack heads..need advice on l26 heads
    GT Level Member crazybrownklick's Avatar
    May 2011
    El paso tx
    Ok so my car got hydrolock due to overheating removed all the engineapart to do a head gasket repair but when took the heads to the machine shop the notice they we're crack and I was wondering if a l36 heads were interchangeable with mine I have a 2004 grand prix l26 engine
  2. #2 Re: Help on crack heads..need advice on l26 heads
    Omaha, NE
    Everyone says they have cracked heads on their 3800s. Do you have pics of how bad your cracks are?
    If you're doing gaskets, why did you take your heads somewhere?
    N/A heads are only interchangable with N/A heads.
    Overheating doesn't cause hydrolock, coolant in the motor does. Hydrolock is in the block, not the heads... Hydrolock - Wikipedia, the free encyclopedia
  3. #3 Re: Help on crack heads..need advice on l26 heads
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    tittle is misleading I thought this was a help group for crack heads lol
  4. #4 Re: Help on crack heads..need advice on l26 heads
  5. #5 Re: Help on crack heads..need advice on l26 heads
    SE Level Member CW2Lido's Avatar
    Pearl City Hawaii
    I had a crack in my head on my N/A 3800 Series II motor in my Crapmaro! It was located in the intake runner for cylinder 2. I assumed this was my only issue with the motor along with a "sticky lifter". I found a set of used heads since there are a lot of them out there and just swapped the old ones out along with new lifters. My mistake was assuming that was my only problem with the motor.
    I realized after I installed the new heads and lifters that the block was overheated due to no coolant. Seems the LIM gaskets were bad enough to cause coolant to leak into the block, which resulted in a spun main bearing and the overheating issue which cracked the head! I was not as knowledgeable as I am now about the motors. Now when I take them apart I dont assume its one thing that caused any issue, I assume the worst and go from there.
    I also love it when people dont perform preventative maintanence on their vehicles. One mans trash is another mans grocery getter!
  1. ZZP Heads VS Intense Heads
    By PurpleGuy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 07:57 AM
  2. N/A Advice... Heads?
    By Bedwards in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-03-2010, 02:22 AM
  3. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
  4. Crack heads!
    By SlowM90 in forum The Rant Forum
    Last Post: 09-07-2009, 11:43 PM
