Thread: Cooling System Flush - most effective way
Results 1 to 10 of 10
  1. #1 Cooling System Flush - most effective way
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    1 more question boys and girls..
    1997 Grandprix GT 4 door, 3800 Series II.
    What is the most effective way you have found to flush the cooling system of its old coolant.
    The reason I ask is because the guy I bought the car from was a parts jockey at the GM dealership, and the car has Dex-Cool in it from a previous flush and fill.
    I'm going to be replacing the coolant elbows at the same time, as per my previous post.
    What's your best way/technique? I will be doing this at work. For those of you who dont know me well (basically all of you..lol) I am a farm equipment mechanic, and have access to most everything. I will be refilling with some off the shelf green coolant.
    Thanks,
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  2. #2 Re: Cooling System Flush - most effective way
    why do you want to replace the dex? you do realize 80% of the things on the shelf at the parts store are a dex type coolant?
    if you have no leaks in your system, the dex is fine and does not need to be replaced with old school green.
  3. #3 Re: Cooling System Flush - most effective way
    Ontario, Canada
    Just figured I'd get rid of it. Over on the S-series forum i'm on that's the first thing everyone recommends getting rid of.
    I have the heads off my 05 Jimmy right now (Intake gaskets turned cam swap turned head job..) and the dexcool made a mess of the passages and ports.
    Jay
  4. #4 Re: Cooling System Flush - most effective way
    it only oxidizes and gunks up if it is exposed to air in the system, IE improperly bled systems and leaks.
  5. #5 Re: Cooling System Flush - most effective way
    I had better luck with green personally.
    Only took 6 months to corrode my blower case.
  6. #6 Re: Cooling System Flush - most effective way
    I tend to flush with a garden hose by pulling the T stat, and unhooking hoses here and there. Flush the heater core, block (6 different directions) rad etc.
    If you have all the possible equipment available.. hook it to a flusher machine and let it go.
    As for coolant..I'd suggest the AnyColor. That way you are covered if there's some residue etc left in the engine block.
  7. #7 Re: Cooling System Flush - most effective way
    Ontario, Canada
    Thanks Bill....
    As for the coolant flush machine.. no go on that one. Do they make one designed fr farm equipment? Some of our combines hold 15 gallons or better..
    Jay
  8. #8 Re: Cooling System Flush - most effective way
    I dunno man.. I live in New England.. we eat what you guys farm
  9. #9 Re: Cooling System Flush - most effective way
    PA
    I do like Bill said. Only I will fill the entire cooling system with water (in the summer) and drive it for a day or so. Drain it, flush it with a hose, and drive it again for a day. Continue doing this until the water that I drain out is as clear as the water going in. It usually takes a couple cycles like that. Then I will drain, pull the knock sensors to drain as much as I can, and even take an air hose on low pressure and blow the water out of the heater core. Then mix up antifreeze with distilled water and fill and bleed properly.
    2001 GSE
  10. #10 Re: Cooling System Flush - most effective way
    utah
    you can make a flush machine with a 5 gal bucket, a ladder or something about 4 feet tal and some hoses and fittings. be it its not a power flush machine, it works without the mess
  1. Cooling System
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2011, 01:44 PM
  2. Help understanding the Cooling System.
    By genesis in forum General Tech Discussion
    Last Post: 12-29-2010, 12:47 PM
  3. Cooling system flush
    By SnowDrift in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2010, 12:16 PM
  4. flush your clogged cooling system on your 3800!
    By Spazztic2003 in forum How To Write-Ups/Tech Tips
    Last Post: 07-02-2010, 12:21 AM
  5. Coolant System Flush
    By zofsharick@gmail.com in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2009, 08:59 PM
