Thread: Please help.. Coolant leak
Results 1 to 3 of 3
  1. #1 Please help.. Coolant leak
    Oct 2011
    Arlington heights, Il.
    i have problem with the intake manifold first on top of the intake manifold betwenn the plenum and intake manifold there was oil and coolant mix... i replaced the intake manifold gasket and the plenum gasket, and again between the two, "intake manifold, and plenum" there was only coolant no oil... i dont know what could be causing the leak on top of the manifold, please help...
  2. #2 Re: Please help.. Coolant leak
    You need to change out the lower intake manifold gasket for the coolant oil mixing problem and the upper intake is prone to cracking on the na cars.
  3. #3 Re: Please help.. Coolant leak
    Oct 2011
    I'll ready replace da lower gasket and the plenum gasket.. could be da intake manifold? but it looks good on top.
  1. Need help..coolant leak
    By Ktrap in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2011, 11:20 AM
  2. bad coolant leak
    By johnfolks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-08-2011, 04:30 PM
  3. My new coolant leak
    By Taz Magister in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2011, 08:31 AM
  4. Coolant leak?
    By LuckyBambu in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2010, 01:59 PM
  5. Coolant Leak..help
    By piperflyer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-07-2009, 10:56 PM
