Does anyone know what the 0-60 time is supposed to be for a 97-03 GT? My 02 is stock, and I timed it tonight and it averaged to about 9.4 seconds. Does that sound about right?
That does seem a little slow. Mine's usually about 9, but your 02 has the 3.29 gearing and my 04 has 3.05 and needs some TLC lol.
Here is my 35-80 i believe, stock gt. Not really relevant, but ya...
video-2011-10-07-19-02-50.mp4 video by joebom123 - Photobucket
Wonder why it would be so slow? I was planning on Seafoaming it sometime soon, think that would make a difference at all?
Ummm, must be the wrong video because you went no where in that one LOL
Here is my GT...It has a custom tune (33* WOT timing), Open Cone Intake, 180*, AL606's gapped at .050", solid lower mounts, poly upper squares/bushings, and a homemade HV3 with a P&P'd Lower Intake Manifold...oh yeah...still has the stock cat/u-bend/dp...lulz.
Easy Roll Out in the Silver Kar to 65 video by bluegtp03 - Photobucket
35 Kick in the Silver Kar video by bluegtp03 - Photobucket
60 Roll in the Silver Kar video by bluegtp03 - Photobucket
Yeah...slowsauce...furealzbreh.
How did you launch it? If you just floored the gas that probably cost a few tenths. If you brake torqued you might pick up a few. Also how did you time it? Maybe your timing method is skewed.
Well that is embarrassing...
Here is the vid i meant to post video-2011-10-05-16-37-58.mp4 video by joebom123 - Photobucket
I had a stopwatch to use as a timer, so I don't think my method is what's wrong... I did just floor it. From what others are saying I'm roughly 1.5 seconds slow either way? It was a fairly cool night, and the car was warm when I tried it out. I'm just gonna hope a clean air filter and seafoam treatment help out a bit
Get rid of that factory U-Bend too...and run a higher octane...it's probably knocking like most factory 3800's and pulling timing above 4k~
here is my 0-60 vid. u-bend/res delete, 08 imp SS catback and fenderwall intake.
1/4 throttle brake launch till it stops spinning and floored it, if you turn ur speakers up you can here the tire trying to break loose again i think lol. once i get to 80-85km/h i hit a hill and it really slows down lol.
Yeah, That hills called 2nd gear!
I agree with you both, 2nd gear is crap. and yes blue even going downhill once you hit second gear that speedo needle slows down lols, but i was starting to hit a hill thats no lie. thats why the video abruplty stops cause im not going to go WOT to the top of a hill cause 1 its dangerouse and 2 the speedo needle would of stopped most likely lols.
