Thread: GT 0-60 times?
Results 1 to 20 of 20
  1. #1 GT 0-60 times?
    Fargo, ND
    Does anyone know what the 0-60 time is supposed to be for a 97-03 GT? My 02 is stock, and I timed it tonight and it averaged to about 9.4 seconds. Does that sound about right?
  2. #2 Re: GT 0-60 times?
    thats slow.
    gtp's about 6.5-7
    gt's should be 8ish Id say
  3. #3 Re: GT 0-60 times?
    GTX Level Member Confusingboat's Avatar
    Minnesota
    That does seem a little slow. Mine's usually about 9, but your 02 has the 3.29 gearing and my 04 has 3.05 and needs some TLC lol.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  4. #4 Re: GT 0-60 times?
    Jun 2011
    Detroit, MI
    Here is my 35-80 i believe, stock gt. Not really relevant, but ya...
    video-2011-10-07-19-02-50.mp4 video by joebom123 - Photobucket
    iLoveSpade
  5. #5 Re: GT 0-60 times?
    Fargo, ND
    Wonder why it would be so slow? I was planning on Seafoaming it sometime soon, think that would make a difference at all?
  6. #6 Re: GT 0-60 times?
    Out West
    Half an hour.
  7. #7 Re: GT 0-60 times?
    do a tune up,
    plugs, wires, fuel filter, air filter, seafoam
  8. #8 Re: GT 0-60 times?
    Florida
    I ran 7.9s- 8.3s stock. So yea you are about a sec off from average. BTW i finally cracked the 6 sec range 0-60 yest at a swift 6.8 sec lol.yay
  9. #9 Re: GT 0-60 times?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    01 GP GT Speedo - Car Videos on StreetFire Heres mine, 35ish to 100ish Semi stock GT
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  10. #10 Re: GT 0-60 times?
    Florida
    Look at this guy freakin show off lol.Pulls good though for so little mods
  11. #11 Re: GT 0-60 times?
    Quote Originally Posted by Hippo Machine View Post
    Ummm, must be the wrong video because you went no where in that one LOL
    Here is my GT...It has a custom tune (33* WOT timing), Open Cone Intake, 180*, AL606's gapped at .050", solid lower mounts, poly upper squares/bushings, and a homemade HV3 with a P&P'd Lower Intake Manifold...oh yeah...still has the stock cat/u-bend/dp...lulz.
    Easy Roll Out in the Silver Kar to 65 video by bluegtp03 - Photobucket
    35 Kick in the Silver Kar video by bluegtp03 - Photobucket
    60 Roll in the Silver Kar video by bluegtp03 - Photobucket
    Yeah...slowsauce...furealzbreh.
  12. #12 Re: GT 0-60 times?
    SWPA
    How did you launch it? If you just floored the gas that probably cost a few tenths. If you brake torqued you might pick up a few. Also how did you time it? Maybe your timing method is skewed.
  13. #13 Re: GT 0-60 times?
    Perhaps...
  14. #14 Re: GT 0-60 times?
    Jun 2011
    Detroit, MI
    Well that is embarrassing...
    Here is the vid i meant to post video-2011-10-05-16-37-58.mp4 video by joebom123 - Photobucket
    iLoveSpade
  15. #15 Re: GT 0-60 times?
    Fargo, ND
    I had a stopwatch to use as a timer, so I don't think my method is what's wrong... I did just floor it. From what others are saying I'm roughly 1.5 seconds slow either way? It was a fairly cool night, and the car was warm when I tried it out. I'm just gonna hope a clean air filter and seafoam treatment help out a bit
  16. #16 Re: GT 0-60 times?
    Get rid of that factory U-Bend too...and run a higher octane...it's probably knocking like most factory 3800's and pulling timing above 4k~
  17. #17 Re: GT 0-60 times?
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    here is my 0-60 vid. u-bend/res delete, 08 imp SS catback and fenderwall intake.
    1/4 throttle brake launch till it stops spinning and floored it, if you turn ur speakers up you can here the tire trying to break loose again i think lol. once i get to 80-85km/h i hit a hill and it really slows down lol.
  18. #18 Re: GT 0-60 times?
    Quote Originally Posted by Grimsin View Post
    You didn't hit a hill, don't lie to me.
    The N/A 3800 is gutless...you could have been going DOWNhill and it still slowed down
  19. #19 Re: GT 0-60 times?
    Hagerstown,Md
    Yeah, That hills called 2nd gear!
  20. #20 Re: GT 0-60 times?
    St Thomas Ontario
    I agree with you both, 2nd gear is crap. and yes blue even going downhill once you hit second gear that speedo needle slows down lols, but i was starting to hit a hill thats no lie. thats why the video abruplty stops cause im not going to go WOT to the top of a hill cause 1 its dangerouse and 2 the speedo needle would of stopped most likely lols.
  1. 97-03 GT-Stock; 0-60 Times?
    By 01PonGPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-20-2011, 09:53 PM
  2. HOW many times do you shift?
    By gptrell502 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-03-2010, 12:05 PM
  3. Track times and a new car!
    By EmEaston24 in forum Off Topic Discussion
    Last Post: 08-02-2010, 09:19 AM
  4. 0-60 times
    By GMCARS4LIFE in forum Off Topic Discussion
    Last Post: 06-30-2010, 04:27 AM
  5. Not exactly kills but times
    By Louie3 in forum Track Sessions and Kills
    Last Post: 05-12-2010, 07:29 AM
