Thread: Running higher grade fuel.
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
  1. #1 Running higher grade fuel.
    GT Level Member Dohner's Avatar
    Montpelier
    I was just wondering if running like 94 octain would give me a noticable power boost. I was at work today thinking about that. I thought i would throw it out on here and see what the pros and cons are of doing this.
    (P.S MY CAR IS A STOCK 02 GT.)
  2. #2 Re: Running higher grade fuel.
    Barksdale AFB, LA
    No, not really. The stock tune is designed to run on regular grade and won't see any benefits from the increased octane.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Running higher grade fuel.
    Montpelier
    Dang that sucks LOL it was just a thought. Thanks alot.
  4. #4 Re: Running higher grade fuel.
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    I also have a stock 2002 gt I got premium awhile ago cause the station was out of regular so it was the same price. I noticed it ran a bit smoother and got slightly better gas milage to that tank. Nothing too spectacular though. I could have just imagined it ran smoother since I knew I had the premium in it, haha.
  5. #5 Re: Running higher grade fuel.
    Montpelier
    Ha Ha i might just have to try some high grade fuel see if i do get better mpg and the runability of the car as long as it wont hurt it. Anyone know of anything bad happening to it if i do run higher grade.
  6. #6 Re: Running higher grade fuel.
    Barksdale AFB, LA
    It won't hurt it. Otherwise there would be a warning that says "No high octane fuel".
  7. #7 Re: Running higher grade fuel.
    TDCRacing
    Guest
    Quote Originally Posted by Sabrewings View Post
    Well put.
  8. #8 Re: Running higher grade fuel.
    SE Level Member snap on's Avatar
    Feb 2008
    Anchorage Alaska!
    Gods honest truth dude thes motors are not built to run premium fuel. It will run it yes. It will run better yes. But if you continue to run premium fuel every time you go to the gas station you will have a massive carbon build up on the motor and it is not very fun what so ever to get that stuff out of your heads. I have seen this so many times in our shop of people running premium and only driving around town. You need to get it out on the highway every now and then.
  9. #9 Re: Running higher grade fuel.
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    i used to always run 93 octane, I got REALLY good MPG with it and I also starting having some idoling problems with it so I still dont use 87 but 89 insted now...but MPG is still great
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  10. #10 Re: Running higher grade fuel.
    Bastard Reptile's Avatar
    Kansas City, MO
    Run the recommended fuel for the car. A GTP is built for premium unleaded, a GT is 87 octane. Running a higher grade fuel usually will result in a loss of horsepower if you don't have the means of maximizing your full potential to run that fuel.
    http://www.grandprixforums.net/f18/w...here-1507.html
    Quote Originally Posted by snap on View Post
    Partially true. Any engine will build up carbon if all you do is putt around town. You've got to clean the cobs out of them every once in a while.
    Cadillacs are notorious for this, because they are basically a performance luxury. The engines are performance designed, but older people buy them. Then they will bring the car back in a few months later complaining it's running bad and pinging. All the tech basically does is put some top engine cleaner in it, then takes it out on the freeway to flog on it.
  11. #11 Re: Running higher grade fuel.
    Montpelier
    Ok i think i will stick to the 87 i dont want any of those issues. Thanks for everyones insite.
  12. #12 Re: Running higher grade fuel.
    Aug 2008
    Seattle, WA.
    Hello New to this forum and my first Pontiac is a 97 Grand Prix SE, Just wondering about arco gas, I hear alot of bad stuff like people don't use it in newer cars, how about in the grand prix's would you recomend arco, or is it better and advised to use shell or cheveron etc.
    Thanks.
  13. #13 Re: Running higher grade fuel.
    Montpelier
    Which company carries arco gas i guess i have never heard of it
  14. #14 Re: Running higher grade fuel.
    Aug 2008
    Seattle, WA.
    Quote Originally Posted by Dohner View Post
    It's a gas station over here in Washington.called Arco there gas is usually 5 - 8 cents cheaper then other gasstations. the only difference I have seen is I got better gas milage from the other gas stations(shell, Cheveron ETC) with my olds, havent went to an arco gas station w/ grand prix.
  15. #15 Re: Running higher grade fuel.
    Montpelier
    OH ok well i cant help you there. Dont know the place or their gas so good luck.
  16. #16 Re: Running higher grade fuel.
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    I have a friend who ran racing fuel in his 2000 V6 Firebird (W/ 3800). He said the gas gauge would move up and down from quarter tank to almost full. It stoped after he was burned it all though.
    Any reason why this might happen?
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  17. #17 Re: Running higher grade fuel.
    Apr 2008
    Chillin at the Beach , VA
    Quote Originally Posted by grand prix newb View Post
    I would watch using that gas, usually a low grade fuel when they can have their price that much cheaper than others. I'd stick with the gas you know.
  18. #18 Re: Running higher grade fuel.
    Barksdale AFB, LA
    Quote Originally Posted by Freebeer187 View Post
    Bad fuel gauge sender.
  19. #19 Re: Running higher grade fuel.
    SE Level Member Ralphie's Avatar
    Aug 2008
    Fort Worth, TX
    I checked out my owner's manual, ('04 GP GT), and it said not to use ethanol because the car wasn't designed for it. I think my local convenience store carries gas with a small amount of ethanol in it. I have been gassing up there about half the time, with no apparent ill effects.
    How serious is this warning?
    -Ralphie
  20. #20 Re: Running higher grade fuel.
    Aug 2008
    Fayetteville, NC
    not sure bro, i wouldnt dare run ethanol in my GP, personally.
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  3. Anyone running an EGT sensor?
    By Andrew_99GTP in forum Turbo
    Last Post: 06-18-2008, 07:13 AM
  4. HELP!! My GP is Only Running On 5 Cylinders!!
    By y1a3o in forum General Tech Discussion
    Last Post: 05-14-2008, 11:20 PM
  5. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
