Hello! We just got my son a 2005 Grand Prix 3.8L. His car will start, idle hard then stall. If we give it a little gas when starting, it fires right up. It does not do this every time.
I've poked around the forums enough to know that I should try cleaning the throttle body. I am a newbie to shade tree mechanics, so bear with my "stupid" questions. I have attached a photo to help clarify any words I happen to type here that make no sense whatsoever.
So, I had my son put the car in ON and press the gas to open the throttle body valve. Sure enough, the inside (closest to the engine) looks black and gunky (verified by the thick nasty stuff under my fingernails after reaching in there). Okay, I bought the Throttle Body Cleaner I've seen on here.
Before I go spraying inside there, I read that I need to remove the MAF. I have conflicting posts as to just where the MAF is located. I thought the MAF was the black plastic thing attached to the side of the TB. But, I read that the MAF is actually to the RIGHT of the TB between the air filter and the TB. I have no idea.
I am trying to clean the TB without removing it from the body of the car because I am pretty sure I would fudge it up. Can a TB cleaning be done while it is still attached? I have read posts where the poster said they "just sprayed in there and wiped it clean" - though I wonder how they cleaned it because I cant get my fingers in there to save my life.
Do I need to remove the black plastic thing on the side of the TB before cleaning? Would it make it easier to clean? Should I just roll the dice and remove the whole TB to clean it?
Sorry for my convoluted question, but I do not want to mess it up nor do I really want to take it to a mechanic if I can do it myself.
Thanks!
