Thread: Egr tube
Results 1 to 3 of 3
  1. #1 Egr tube
    Jersey
    Hey gp heads! I have a P0401 code for low egr flow so i recently got a new egr valve. Ive read in the haynes repair manual that for the v6 engines you have to disconnect the egr pipe at the exhaust manifold, but for some reason i cant seem to find it. Im guessing i have to clean that tube as my engine light is still on. Help will be appreciated
  2. #2 Re: Egr tube
    On your engine, EGR flow is checked by the map sensor. Keep this in mind if the pricey EGR doesn't fix the issue.
    Your egr is held on by two 13mm nuts. Undo them from the top, lift.. clean and replace the gasket. Bolt new one on.
    Here's the bracket and both tubes off the engine, upside down. That stud you see is one of the two that hold the egr on.
  3. #3 Re: Egr tube
    Jersey
    Thanks man. Update...i just changed the spark plugs finally and the light went off lol, unbelievable
  1. about the egr tube
    By mhartwig in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-10-2013, 06:59 AM
  2. EGR Tube
    By bronze93 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 07-06-2010, 05:27 AM
  3. egr tube question
    By 05SS45 in forum General Tech Discussion
    Last Post: 05-12-2009, 10:09 AM
  4. Orifice Tube
    By Damojo2003 in forum General Tech Discussion
    Last Post: 04-23-2009, 05:14 AM
