Thread: Ever bypassed the power steering pump?
Results 1 to 20 of 33
  1. #1 Ever bypassed the power steering pump?
    Tucson, AZ
    I understand it's no longer term solution, as it will trash the rack and pinion, but has anyone used a shorter than stock belt and bypassed the power steering pump?
    I'm doing my best to help my mechanically DEclined brother, who has no tools, is broke and is leaving it up to me to fix the car. Unfortunately, it's all over the phone at this point, as I have no time to go replace the power steering pump until this weekend, and I just want him to get the car home.
    If you've bypassed the power steering and know of a belt that will fit, please let me know. Thanks.
  2. #2 Re: Ever bypassed the power steering pump?
    Does your brother have a strong upper body?
  3. #3 Re: Ever bypassed the power steering pump?
    Charles City, IA
    You cant just run a shorter belt, due to teh way its routed.
    SMGPFC Two Nipple General
  4. #4 Re: Ever bypassed the power steering pump?
    http://www.grandprixforums.net/websi...ts/pulleys.jpg
    eh you might be able to pull it off..
    alt to back side of tensioner then around water pump.
  5. #5 Re: Ever bypassed the power steering pump?
    Charles City, IA
    I guess it might work.
  6. #6 Re: Ever bypassed the power steering pump?
    how far does he need to drive it?
    if its all highway, just drive it, but tell him to have the car rolling when he try's to turn it, (like dont ape it when the car is sitting still) or for sure the rack will die.
    i wouldn't waste my time (or money) buying a new belt to reroute it past the p/s pump, if its dead its dead, cant do any more damage to a dead part.
  7. #7 Re: Ever bypassed the power steering pump?
    Tucson, AZ
    I'm not trying to salvage the PS pump, I'm just not wanting him to drive the car with, essentially, no water pump. Thanks for the input, guys.
  8. #8 Re: Ever bypassed the power steering pump?
    Tucson, AZ
    Maybe by now, since he's been driving it with no PS fluid for a while, even though I told him to put PS fluid in it.
  9. #9 Re: Ever bypassed the power steering pump?
    Charles City, IA
    Why are you trying to bypass teh pump if he is driving it now?
  10. #10 Re: Ever bypassed the power steering pump?
    Quote Originally Posted by fju2 View Post
    why would the water pump not be working?
    i drove with a shot pump and shot rack for about a month, the water pump still worked the whole time.
    your only fear should be the rack quitting on you after the pump is installed.
  11. #11 Re: Ever bypassed the power steering pump?
    Charles City, IA
    If the belt is still on the water pump is working.
  12. #12 Re: Ever bypassed the power steering pump?
    Tucson, AZ
    The belt's not on and the PS pump is frozen up, which throws the belt, hence the reason I'm looking to temporarily bypass the PS pump.
  13. #13 Re: Ever bypassed the power steering pump?
    Tucson, AZ
    Quote Originally Posted by TheOtherNick View Post
    He is no longer driving it, and it's parked in a random parking lot in Tucson. If you know anything about Tucson, you may know you don't want to leave your car anywhere other than your home for any length of time. I'm just wanting him to get it home, and he has no money to have it towed.
    The PS pump is now frozen, so the belt slips off almost immediately after the engine is started. If driven without a belt, the water pump obviously doesn't spin, causing the engine to overheat.
  14. #14 Re: Ever bypassed the power steering pump?
    Waukesha, WI
    drive till it starts to overheat then shutoff, let it cool down and drive again?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  15. #15 Re: Ever bypassed the power steering pump?
    well if that belt diagram is to scale... one could guestimate the length.
  16. #16 Re: Ever bypassed the power steering pump?
    sounds like your going to have to get to him to fix it, i wouldn't drive it then, at all.
    you did leave the part out where the pump is frozen. important info there.
  17. #17 Re: Ever bypassed the power steering pump?
    Tucson, AZ
    Not really. I mean, I do appreciate all the input, but I wasn't looking for alternate solutions. I know what needs to be done long term, I was just wanting to know if someone has bypassed the PS pump with a different sized belt.
  18. #18 Re: Ever bypassed the power steering pump?
    Tucson, AZ
    Quote Originally Posted by redlinepontiac View Post
    I thought of that, but hate the idea of repeatedly taking the car to the brink of overheating.
  19. #19 Re: Ever bypassed the power steering pump?
    i hear ya, but thats not something you would do, not even as a temp job to get you by. and a waste of a belt that you will never use again.
    hell if you think about that belt will run upwards of 50 bucks, a socket set is 25 bucks. a pump 70 bucks. if you like send me the 50 for the belt and ill buy pot with it, same thing, its up in smoke
  20. #20 Re: Ever bypassed the power steering pump?
    Charles City, IA
    You should have said it was locked up in the first place. A tow will be cheaper then the time you will have in trying to get a shorter belt to work.
  1. 99 GT power steering pump
    By BmoreDrew in forum General Tech Discussion
    Last Post: 04-10-2011, 11:13 PM
  2. noisy power steering pump?
    By Teardrop in forum General Tech Discussion
    Last Post: 12-26-2010, 10:01 PM
  3. Need New Power Steering Pump?
    By brandonl2000 in forum General Tech Discussion
    Last Post: 12-05-2010, 01:59 PM
  4. power steering pump
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2009, 04:26 PM
  5. Power Steering pump
    By airhead in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2008, 07:16 AM
