Thread: Powerlog and 10.4mm PRJ's
Results 1 to 20 of 20
  1. #1 Powerlog and 10.4mm PRJ's
    Oxon Hill, MD
    Just installed my 304 Coated PLOG, AL605s and 10.4mm wires. Install was gravy on the powerlog. The plugs and wires left me with a few nicks and scratches but I'll live.
    There's a lot more room on the back of the 3800 than the 3400, but the front plugs on the 3400 are much easier to work on. I guess they both have their maintenance difficulties.
    Overall, I'm really pleased with the gains. No more light KR except at WOT at the top of each gear. I assume that it's leaning out. Pulls great through the entire rpm range. The engine seems a little louder inside the car too.
  2. #2 Re: Powerlog and 10.4mm PRJ's
    Barksdale AFB, LA
    2009 Subaru Impreza WRX STI
  3. #3 Re: Powerlog and 10.4mm PRJ's
    Oklahoma
    Awesome. I really wish ZZP would make a rear PLOG that would work with the EGR and such. I know there's not as much restriction back there, but it still would be nice to have.
  4. #4 Re: Powerlog and 10.4mm PRJ's
    Bastard Reptile's Avatar
    Kansas City, MO
    Good Lord those wires are huge!
  5. #5 Re: Powerlog and 10.4mm PRJ's
    Barksdale AFB, LA
    Quote Originally Posted by Reptile View Post
    I know. I have a set.
  6. #6 Re: Powerlog and 10.4mm PRJ's
    SE Level Member The_Avenger's Avatar
    Ontario, Canada
    Very nice I cant wait to get together some money for the Plog and a DP. The wires are awesome aswell!
    2004 Grand Prix GT - 75xxxkm - Inferno Package (no hood), Wizaired CAI, ZZP Strut Tower Brace, 180 T-Stat, Throttle Body Heat Shield, more to come...
  7. #7 Re: Powerlog and 10.4mm PRJ's
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    I have the wires as well. I'd say don't get them for performance reasons - get them to give you engine some pop. I got red for my Impala for some contrast. For my GP, when I had them replaced I just had AC Delcos.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  8. #8 Re: Powerlog and 10.4mm PRJ's
    Barksdale AFB, LA
    Quote Originally Posted by Deezul_AwT View Post
    I got them for durability above other reasons. The stockers tore up as I took them off.
  9. #9 Re: Powerlog and 10.4mm PRJ's
    Feb 2008
    Cumming GA
    Quote Originally Posted by Sabrewings View Post
    True. When I took the factory wires off, I didn't even try to do it easy knowing I'd be swapping. I have been able to remove factory ones doing it slow and steady. What I don't really like about the PRJs is they don't completely cover the plugs.
  10. #10 Re: Powerlog and 10.4mm PRJ's
    Barksdale AFB, LA
    This happened while trying to remove my factory plugs.
    http://img.photobucket.com/albums/v3...2/DSC02367.jpg
    Boot tore straight off the crimp. I also hated the factory heat shield setup. Glad I no longer have it.
  11. #11 Re: Powerlog and 10.4mm PRJ's
    GT Level Member njbrain's Avatar
    Rhinelander WI
    Looks great. I've got them as well. They definitely get attention everywhere, and look really good.
  12. #12 Re: Powerlog and 10.4mm PRJ's
    May 2008
    staten island,NY
    do any of you guys change your rear plugs like this??
  13. #13 Re: Powerlog and 10.4mm PRJ's
    TDCRacing
    Guest
    LOL nooooo of coarse not lol
  14. #14 Re: Powerlog and 10.4mm PRJ's
    Oxon Hill, MD
    Quote Originally Posted by QwikGT View Post
    That looks about right. Knees on the radiator support and supporting yourself with the strut tower brace.
  15. #15 Re: Powerlog and 10.4mm PRJ's
    Feb 2008
    Cumming GA
    I broke a few of the fins on my Impala's alternator before I found a good place to put the ratchet straps and rotate the engine. It's been working fine for the past year.
  16. #16 Re: Powerlog and 10.4mm PRJ's
    GTP Level Member David99GTP's Avatar
    Florida
    Same thing happened to mine. I thought what a bunch of cheap crappy wires.
    I like the look of my PRJs, they def get attention when people look under the hood. Plus coming from Paul you know they are good quality and will last
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  17. #17 Re: Powerlog and 10.4mm PRJ's
    Barksdale AFB, LA
    Quote Originally Posted by David99GTP View Post
    I've already had to take them off a few times working on my exhaust, and they come off easy and go on easy. Could have something to do with making sure I put dielectric grease each time, but regardless the huge boots let you get a good grip. And being bendable makes it even better!
  18. #18 Re: Powerlog and 10.4mm PRJ's
    I live here. UR LOSN's Avatar
    Rockford, IL
    Looks awesome!!
  19. #19 Re: Powerlog and 10.4mm PRJ's
    Oxon Hill, MD
    Thanks for all the comments guys.
    Having that M90 on top must really get in the way. I changed the rears without even touching a ratchet strap. But then again, you've seen how scrawny my arms are.
  20. #20 Re: Powerlog and 10.4mm PRJ's
    Feb 2008
    Cumming GA
    Quote Originally Posted by whitelightnin04MC View Post
    Haha. The work I did on my Impala was the first time I decided to do a lot of work myself. The biggest thing I did before then, outside of oil changes, was changing a fuel filter. So I wanted to make sure I did it right on the Impala.
