Hey folks,
I'm looking for a diagram of the 2005 Grand Prix (Base Model) serpentine belt pattern.
Anybody???
Hey folks,
Anybody???
Thanks boss!
I just finished installing a new alternator & serpentine belt. I've noticed two things since doing so :
1) When in park, if I hit the accelerator my car now cuts off power not allowing the RPM's to go above 4000. I don't think this ever happened before (although I'm not 100% certain). When on the road, there's no problem, so it might be a safety feature on this "new" alternator.
2) One edge of the belt is straddling the pulley right up on the edge of the pulley. I'm a bit concerned that it might fall off in time. Is this out of the realm of possibility or are my fears founded?
Lil' help?
Rev limiter eh? I don't think that feature was there before I put this new alternator in.
Anyways, thanks for the heads up though....I'm learning.
I also noticed something else; with my old alternator whenever I hit speeds of 160 km/h it would cut out; not allowing me past that speed. Today, I took her out for a test drive and she flew past 160 km/h. I was shocked that I could do this. It's definitely the alternator because I could never do that before. I bought my car second hand, and I'm quite sure my alternator was the original one. Do you think it's a limitation on the O.E.M alternator?
Lastly, I installed a new battery today; a Motomaster Eliminator Spiral Grid Battery from Canadian Tire. Two things :
1) The posts are in the middle of the battery which made hooking it up a real pain in the....well, you get the idea. Why would they position it in the middle of the battery like that?
2) When I tried to refasten the nut to the battery posts/terminals, sparks started flying everywhere! It was like when you put a negative cable to a positive cable. I couldn't really fasten the nut properly. Oh, and just so we're clear....the cables are definitely on correctly (negative on the negative post, positive on the positive post). I don't understand why this happened. Can somebody please explain?![]()
The speed limiter is in the PCM. The alternator has nothing to do with that.
Any takers?
Anybody?
I've done a search online and I just can't find an answer to this one.![]()
Like he said. Alternator has nothing to do with that
