Thread: Where Is The Relay For The Secondary Air Injection System?
Results 1 to 8 of 8
  1. #1 Where Is The Relay For The Secondary Air Injection System?
    SE Level Member jarkayman's Avatar
    Aug 2011
    CNY
    Anyone know? I can't find this anywhere online. It's not on my Alldata account and it's driving me nuts!
    Car's an 07.
  2. #2 Re: Where Is The Relay For The Secondary Air Injection System?
    I had a car in recently. If you can, go by NU3 for an RPO code. That's teh cali emissions, where the pump would come into play.
  3. #3 Re: Where Is The Relay For The Secondary Air Injection System?
    Aug 2011
    CNY
    What does that mean?
    I just want to know where the relay is located so I can make sure it's working.
  4. #4 Re: Where Is The Relay For The Secondary Air Injection System?
    Since I'm not sitting in front of a manual. I tried to help you figure out how to look it up.
    NU3 = crappy California emissions secondary air pump bs on your car.
    Meaning, if there's a question that comes up from AllData, you want to select NU3 based cars. In the GM FSM it specifically asked. If you don't select it... no relay info, no pump info..no anything else info relating to it.
    Beyond that attemp at help, I'd be stating the obvious "in the relay center". And we all know that's not what you are looking to hear. Surely you checked there already.
  5. #5 Re: Where Is The Relay For The Secondary Air Injection System?
    Aug 2011
    CNY
    It's not in with the other relays. From what I could find online it's over near the air intake. There was one good size relay there that I did check, but I'm not 100% I have the right one.
    Thank you for the Alldata tip. I'll try that. I have a subscription for that specific vehicle. Whenever I do a search on the Secondary Air Injection System Relay, it just give me a diagram of the actual relay.
  6. #6 Re: Where Is The Relay For The Secondary Air Injection System?
    Quincy, Mass
    its in the front bumper, drivers side. if you take the bumper off its really easy to get to, but i think you can get to it if just take the wheel well out.
    No more GP 04 Impala SS Indy:
  7. #7 Re: Where Is The Relay For The Secondary Air Injection System?
    Aug 2011
    CNY
    Quote Originally Posted by Swiggles View Post
    Thank you!
    I found the schematic on Alldata but still couldn't find anything related to the location.
    If the code comes back and I have to get in there testing, you have saved me a lot of searching.
  8. #8 Re: Where Is The Relay For The Secondary Air Injection System?
    Quincy, Mass
    well thats where it is on my 2000. there should be a big rubber vacumm line going to it so if find that follow it the canister and then youll find the relay.
  1. P0410 Secondary Air Injection System Malfunction
    By NaturallySmashed in forum General Tech Discussion
    Last Post: 07-09-2010, 11:36 PM
  2. Secondary air injection pump
    By dkbc3 in forum General Tech Discussion
    Last Post: 07-28-2009, 05:31 AM
  3. Replies: 2
    Last Post: 04-28-2009, 12:13 AM
  4. Replies: 2
    Last Post: 04-06-2009, 12:37 PM
  5. Help!!! Trans,Front End,Secondary air injection PROBLEMS!!!!!
    By 00gpgt in forum General Tech Discussion
    Last Post: 04-02-2009, 08:56 PM
