Thread: 3800 Rough Idle-High RPM
Results 1 to 6 of 6
  1. #1 3800 Rough Idle-High RPM
    Jul 2011
    midwest
    We have got a 97 grand prix that has been an excellent car until now. When starting it up-the idle is rough, right around 1000 rpm. Going down the road the rpm will continue to rise on its own and will not come down-creating the car to accelerate, creating a dangerous situation. When put in neutral it will rev very high. I dont think that the throttle is sticking, but thats what it acts like. Any suggestions. Thanks in advance.
  2. #2 Re: 3800 Rough Idle-High RPM
    A scanner would be great. Most likely it's a TPS sensor, but it could also be an IAC soleniod.
  3. #3 Re: 3800 Rough Idle-High RPM
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    Maybe a vacuum leak? Check all your vacuum lines and listen for a sucking sound.
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  4. #4 Re: 3800 Rough Idle-High RPM
    Jul 2011
    midwest
    found the problem. vacuum leak where a line plugs into the front of the throttle body. Dry rotted line. Thanks
  5. #5 Re: 3800 Rough Idle-High RPM
    Hoooooooooray vacuum leaks!
  6. #6 Re: 3800 Rough Idle-High RPM
    Jul 2010
    Houston, Texas, United States
    ^ exactly could have been more expensive to fix than that,be glad friend be glad.
  1. rough idle
    By 02gtpalder in forum General Tech Discussion
    Last Post: 03-07-2010, 12:02 AM
  2. rough idle 02 gtp
    Last Post: 03-06-2010, 01:16 PM
  3. 91 GP rough idle
    By Juanmiguel in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-04-2010, 11:07 PM
  4. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  5. Rough Idle
    By Red_GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 02:29 PM
