Thread: 05 grand prix base
Results 1 to 20 of 22
  1. #1 05 grand prix base
    Jul 2011
    chippewa
    ok so this is what it does, it hesitates sometimes. it don't do it all the time and when it is doing it, i can stop, shut it off and restart it and then it's ok again. it's mostly when i'm accelerating it notice its like gutless and kinda shifts hard. My boyfriend thought catalyic converter so we just replaced that and it still does it. we also replaced the plugs and wires and that didnt help. My engine light is on.. and the only code the computer brought up was that there's a small evap leak or the gas cap isn't tight or something..which it is. i'm getting really frustrated with this. lol plez help any ideas?
  2. #2 Re: 05 grand prix base
    Jul 2011
    chippewa
    ooh and it idols just fine. It's mainly when i'm taking off and i have noticed it when i am up to speed once in a while..
  3. #3 Re: 05 grand prix base
    Topeka, KS
    Post the trouble code.
    Like P0xxx.
    My wifes g6 does this when it's hot and the dealer can't figure it out either.
    Whens the last time you changed the fuel filter ? (Simple fix.)
    Run a can of seafoam through the gas tank to clean the injectors.
    YouTube - ‪Seafoam Motor Treatment and Introducing NEW Seafoam Spray‬‏
  4. #4 Re: 05 grand prix base
    Jul 2011
    chippewa
    I'm not sure what the trouble code is? I mean i don't know it offhand anyways? I just bought this car about 4 months ago and so i've never replaced the fuel filter anyways.. I'm pretty sure the last owners didn't keep real good care of it so hard telling when they had it changed?
  5. #5 Re: 05 grand prix base
    Jul 2011
    chippewa
    is seafoam like fuel cleaner? cuz i know my bf ran some kinda clean through my gas tank..
  6. #6 Re: 05 grand prix base
    Topeka, KS
    Ya fuel and engine cleaner. It's the best on the market in alot of peoples opinions. Do it through the vacuum line like that video shows.
    We just need to the Engine Light code that comes up to help diagnose. Take it to autozone or someplace and have a scanner hooked up to it. Then report back with the "P" code.
  7. #7 Re: 05 grand prix base
    Jul 2011
    chippewa
    ok will do. thanx for the help
  8. #8 Re: 05 grand prix base
    Topeka, KS
    NP
  9. #9 Re: 05 grand prix base
    GTP Level Member joshv's Avatar
    canada
    my o4 gp has the same thing, and iv replaced the gas cap and its allways on, its just a stupid code problem it used to bother me but now i dont care lol
  10. #10 Re: 05 grand prix base
    Jul 2011
    chippewa
    you engine light is on? or your gas cap light? lol thats if there is even a gas cap light? cuz i only have the engine light on. The previous owners lost the manual so i don't have a handly manual to look things up quickly Your car does the hesitation stuff though?
  11. #11 Re: 05 grand prix base
    Nov 2010
    White Lake, MI
    Quote Originally Posted by kmk2005 View Post
    My 2005 3.8 N/A base has the same symptoms. The car hesitates only once in a while and I can shut it off, then start and it will go away. The acceleration is exactly as yours, sluggish and jerky. My engine light is on with a p0455 code (leak evap system). The dash information says check gas cap. The cap is on and have purchased new ones.
    Have you found a solution?
    If anyone knows the solution or how to approach this situation let me know.
    2005 Pontiac Grand Prix, Base, 3800, N/A
  12. #12 Re: 05 grand prix base
    Jul 2011
    chippewa
    Ugh ya I have not found a solution yet unfortunatly. I know replacing the spark plugs and wires, and replacing the catalyic converter didn't help. It still does it. If you happen to find a solution before me you should let me know
  13. #13 Re: 05 grand prix base
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    i changed my whole evap canister.. and lines.. on my 97 it turned da ces light off.. different year.. same light..
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  14. #14 Re: 05 grand prix base
    Jul 2011
    chippewa
    Did your car do the hesitating and feel boggy though? and did it help when you replaced that?
  15. #15 Re: 05 grand prix base
    With the newer GM cars...I've found the new style EVAP canisters to fail quickly...they are pretty cheap...like 20 or 30 bones. My Cobalt I had chucked 2 EVAP canisters during the couple years I owned it. Also...'04+ cars suffer from gunked up throttle body issues...which can cause hard starting or stumbling...remove the intake tubing...unbolt the 4, 10mm bolts that hold the TB on...unplug it...yank it off and clean it with brake clean and a towel you don't care about...and toss it back on.
  16. #16 Re: 05 grand prix base
    Nov 2010
    White Lake, MI
    Thanks for the info.
    Is the canister located about the drivers side wheel well?
  17. #17 Re: 05 grand prix base
    It should actually be in front of the intake manifold on the middle/left hand side.
    If its in the same place as my '98.
  18. #18 Re: 05 grand prix base
    Jul 2010
    Home
    For your car (04+), yes. Rear drivers wheel well. If I recall, one bolt to remove the canister and bracket holdin it on. It is slightly behind the wheel well almOst on top of the muffler (if you have a muffler on the drivers side). Easy and cheap fix for a pain in the ass problem.
    Exactly the same symptoms as you. Gas cap warning on the DIC and occasionally a CEL that would go away the next day. Bought the gas cap ... Waste of $40 from the dealer. Went in and asked. They told me right away what to replace. They said that they stock a few because they apparently go out all the time. Haven't had an issue since I replaced in January (fingers crossed)
  19. #19 Re: 05 grand prix base
    Nov 2010
    White Lake, MI
    So for an update, I replaced the evap canister about 3 weeks ago and the check engine light and DCI have been clear, no issues. The canister on my 05 is located right by the fuel filler neck, behind the rear drivers side wheel.
    Took about all of 15 min, 1 bolt to remove.
    Part: ACDelco 214-2147 OE Service Vapor Canister Purge Valve
    Thanks for the help! Up next cleaning the throttle body.
  20. #20 Re: 05 grand prix base
    Good deal...cleaning the throttle body is WAY easier LOL
  1. Supercharger for '07 grand prix base model 3.8 L26
    By tino153 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-26-2011, 08:14 PM
  2. Cold Air Intake on base grand prix???
    By rashan in forum General Tech Discussion
    Last Post: 09-29-2010, 01:25 PM
  3. 2008 Grand Prix Base Wheels
    By ajaxjblue in forum Tires & Wheels
    Last Post: 10-05-2009, 12:33 PM
  4. TC on a 2006 base grand prix
    By nrfitchett4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2009, 06:06 AM
  5. 235/50-18 will these fitt base model 06 Grand Prix?
    By Shake_Zula in forum Tires & Wheels
    Last Post: 02-17-2009, 02:07 PM
