Thread: Solid rubber motor mount
Results 1 to 12 of 12
  1. #1 Solid rubber motor mount
    GT Level Member jmoore4294's Avatar
    Anyone know where to get a solid motor mount besides ZZP? I've got the solid tranny mount that ZZP sells, but I got it from autozone for almost $30 less. If I could avoid paying ZZP $60 for a motor mount I will. But I can't find a solid one. I've looked on rockauto, autozone, advance, oreillys and napa to no avail.
    2004 Pontiac Grand Prix GT2 -Wizaired-DHP Tune-180° Thermostat-GMPP STB w/brackets F/R-Bilstein HD Struts w/SSC-Projector Retro-Black SPO Grilles and Spoiler-ZZP Volt. Booster & Alt Rewire
  2. #2 Re: Solid rubber motor mount
    Charles City, IA
    ebay.com
    SMGPFC Two Nipple General
  3. #3 Re: Solid rubber motor mount
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    My local napa had both of them!
  4. #4 Re: Solid rubber motor mount
    Would this one work? Found this part # in the wbody.com archive on google.
    https://napaonline.com/Catalog/Catal...006359131&An=0
    Part #: 6121730
  5. #5 Re: Solid rubber motor mount
    Dec 2008
    Lawndale, CA
    I got mine from oreilly's. I had to have them order it. Just be sure to shake it to hear if there is any fluid inside it before you buy it.
  6. #6 Re: Solid rubber motor mount
    Ok, so logically speaking, the motor mount for 97-03 should fit 04+ GPs right?
  7. #7 Re: Solid rubber motor mount
    Dec 2008
    Lawndale, CA
    It should. I would have to see a photo of it to see what the 04+ one looks like.
  8. #8 Re: Solid rubber motor mount
    Not sure the differences....but...at Az
    '97-'03 Mount = #2796
    '04-'08 Mount = # 2987
  9. #9 Re: Solid rubber motor mount
    Grand Rapids, MI
    they were available for me online at autozone.
    but also they were available at the local napa warehouse, not the regular sales location.
  10. #10 Re: Solid rubber motor mount
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    They should be available at AutoZone. IIRC, you have to select the supercharged engine to get to it.
  11. #11 Re: Solid rubber motor mount
    Quote Originally Posted by tdm571 View Post
    Not true. Engine selection has nothing to do with it...I can get a solid rubber replacement for basically ANY car that has a factory fluid filled mount. You just have to ask for the solid rubber OPTION.
  12. #12 Re: Solid rubber motor mount
    Lakeside Park, KY
    I was wrong about the solid engine mount only showing up under the supercharged engine. It was the solid transmission mount that I was thinking of. Feel free to try it on autozone.com.
  1. Cheapest solid motor mount
    By Jay7199 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2011, 09:05 AM
  2. Napa solid rubber mounts part #s?
    By blown98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2009, 08:21 PM
