Thread: Below normal fuel pressure- backfiring under throttle
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21 Re: Below normal fuel pressure- backfiring under throttle
    Donating Users triebenbach07's Avatar
    Dec 2010
    long prairie, mn
    i hate to revive a dead thread, but i am having the same issue on cylinder #1. was the injector the problem?
    -02 top swap
    02 sedan, top swap
  2. #22 Re: Below normal fuel pressure- backfiring under throttle
    Northern Vermont
    The flow matched injectors helped, I found a cracked injector hat on cylinder 3, but it's not perfect yet. Still at full throttle it's not totally running right. I don't think this one has had a intake manifold gasket job yet, and I would bet having a AFPR -Adjustable fuel pressure regulator) would allow me to compensate for a slight air leak on one of the cylinders that is backfiring. So I bought one from a guy who had a supercharger kit takeoff on a firebird, with the same style fuel connectors and I am going to try that.
  3. #23 Re: Below normal fuel pressure- backfiring under throttle
    Dec 2010
    long prairie, mn
    so i spent a few hrs fiddling around today. my problem was that a spark plug had failed internally. it looked fine on the tip and had no cracks., kinda pissed me off cause it was such a simple fix.
    nonetheless, i hope the AFPR works for you
    02 sedan, top swap
  1. Is this normal? Replacing fuel pump in 2003 Grand Prix
    By GrandPrixlbc in forum General Tech Discussion
    Last Post: 08-11-2011, 08:51 AM
  2. Average/normal oil pressure
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2010, 02:12 PM
  3. Fuel pressure 04+
    By OH4CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2010, 09:04 PM
  4. WOT fuel pressure
    By Sabrewings in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-05-2009, 12:38 AM
  5. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
