Thread: Service ABS, traction control, variable steering
Results 1 to 15 of 15
  1. #1 Service ABS, traction control, variable steering
    SE Level Member Lionel's Avatar
    Moncton N.B.
    This happened before, but was fine after i shut off the car and started it again.
    this time it isnt going away, i have no abs, no traction control and it is harder to turn my steering wheel. the center console tells me to service those three things, they were all working fine before.... what is the cause of this, anyone ever hear of it?
  2. #2 Re: Service ABS, traction control, variable steering
    Moncton N.B.
    Also, I know my driver's side wheel bearing is bad, not sure if that has anything to do with it.
    but why would that disable my steering?
  3. #3 Re: Service ABS, traction control, variable steering
    GT Level Member Tea Time's Avatar
    New Brunswick
    the sensor on ur bearing is prolly bad therefore throwing the codes for trac n abs....have u checked ur power steering fluid lately?...is there a whine when u turn the wheel?
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  4. #4 Re: Service ABS, traction control, variable steering
    Moncton N.B.
    I'll check the PS levels and no there was no noise when i cut the wheels.
    If it is the sensor is that something you buy? or does it come with the hub assembly? I need to replace the bearings anyway.
    Also this problem started after driving on a very bumpy road if that helps.
    Just noticed you are a fellow New Brunswicker! I'm sure you know exactly what i mean by very bumpy roads lol
  5. #5 Re: Service ABS, traction control, variable steering
    New Brunswick
    yep...the fact it started on a bumpy road helps...the sensor is built into the new hub assembly(bearing) that u get...
    The steering has me confused tho....does it feel like theres no assistance from the power steering?
    and the roads suck here...
    '97 GTP - Project
  6. #6 Re: Service ABS, traction control, variable steering
    Moncton N.B.
    The power steering still works but its much stiffer, (its better then when the car is off but its noticeably harder than before the warning came.)
    My traction control and abs no longer work either.
    My PS fluid looks fine.
  7. #7 Re: Service ABS, traction control, variable steering
    New Brunswick
    its a a long shot but, ur not missing a serpentine belt r u?
    '97 GTP - Project
  8. #8 Re: Service ABS, traction control, variable steering
    Moncton N.B.
    No, my belt is fine, My brakes work, just not the abs. and my power steering works, just not as much as it did, its stiffer.
    Once I replace the hub assembly, I'll repost with an update.
  9. #9 Re: Service ABS, traction control, variable steering
    Apr 2011
    Ohio
    Did you ever fix this??? I'm having the same problem
  10. #10 Re: Service ABS, traction control, variable steering
    Moncton N.B.
    I'm pretty sure its my hub assembly, the abs sensor. I have a bad wheel bearing, I just haven't gotten around to replacing it yet. Are your bearings good?
  11. #11 Re: Service ABS, traction control, variable steering
    Apr 2011
    Ohio
    Pretty sure mine are shot as well... Not THAT noisy but I can tell they need replaced
  12. #12 Re: Service ABS, traction control, variable steering
    SE Level Member 04GTP956's Avatar
    RioGrandeValley
    im having the same problem with my car, do you know how to check and see which wheel hub needs replacement??
    RIDE:2004 GTP COMP-G
  13. #13 Re: Service ABS, traction control, variable steering
    New Brunswick
    shake the top of the wheel back and forth from the side of the car...if its bad, u'll feel play when shakin the wheel.
    '97 GTP - Project
  14. #14 Re: Service ABS, traction control, variable steering
    SE Level Member brianwalter86's Avatar
    Apr 2011
    michigan
    my car was doing the same thing. and i just replaced the wheel bearing today. problem solved.
    and shaking the tire isn't always accurate. mine didn't have any play at all.
    not to mention if your wheel bearing isnt bad it could be the wires leading to your wheel hub assembly or even both.
    you could try cleaning the wire plugs. i was told you can use brake cleaner on them.
  15. #15 Re: Service ABS, traction control, variable steering
    Apr 2011
    michigan
    by the way from what peopel have told me buy a timkin wheel bearing. only $90 at RockAuto Auto Parts
    you can get the part number from autozone.com. same one is $317 at autozone
  1. Comments Wanted - 05 Comp G Service Stability/Service Traction
    By JD05CompGTP in forum General Tech Discussion
    Last Post: 03-13-2012, 08:21 PM
  2. service power steering abs system traction control warning
    By ltr450tremor in forum General Tech Discussion
    Last Post: 05-06-2011, 10:14 PM
  3. Reduced Engine Power/Service Traction Control
    By SteveNMe in forum General Tech Discussion
    Last Post: 08-07-2010, 10:36 AM
  4. 04 GTP Service ABS/ TRaction control
    By busagtp in forum General Tech Discussion
    Last Post: 09-07-2009, 12:03 PM
