Thread: oil level low
Results 1 to 13 of 13
  1. #1 oil level low
    GT Level Member johnnyj773's Avatar
    May 2008
    Chicago(southside)
    i just got my oil changed in may and 2 days ago my low oil light came on.what could be the cause of this?a leak?
    Wizaired cai,taylor 8mm wires,ngk tr55 plugs, msd coils.slp power flo exhaust w/gtx tips. future mods:zzp 1.0 pcm,slp headers, zzp hv3 uim runners ,zzp hv tb,gmpp sway bars,kyb agx struts,18"A.R.M:Rogues wrapped in firestone firehawk gt's.that's all performance wise.
  2. #2 Re: oil level low
    Barksdale AFB, LA
    Could be leaking, could be burning it.
    2009 Subaru Impreza WRX STI
  3. #3 Re: oil level low
    Saraland Alabama
    check the level, the sender could be bad
  4. #4 Re: oil level low
    Oklahoma
    Quote Originally Posted by archemedes View Post
    Thats what I was thinking. You'd have to lose over half your oil for it to trigger the sensor and I dont see that happening without some sign or symptoms of trouble. The bad side of it is that you have to drain the oil out to change it, or at least get it below the level of the sensor hole in the pan. If you end up replacing it, be sure to use some thread sealant.
  5. #5 Re: oil level low
    May 2008
    Chicago(southside)
    okay today i hopped in and now its off.???
  6. #6 Re: oil level low
    Racine, WI
    You know you can always check the dipstick. Sensors can go bad.
  7. #7 Re: oil level low
    May 2008
    Chicago(southside)
    i checked the level its fine.must be the sensor .can i go with it til my next oil change?
  8. #8 Re: oil level low
    Saraland Alabama
    all it does is turn on the light so sure
  9. #9 Re: oil level low
    May 2008
    Chicago(southside)
    phew!i payed too much for that damn oil .lol.so just so i can know in the future,what causes oil to burn?and what gaskets can cause it to leak?
  10. #10 Re: oil level low
    May 2008
    Chicago(southside)
    thats what might end up happenin.this might sound dumb but i need to know;whats thread sealant?where can i find it?and what exactly am i sealing?and thanx everybody for your input,good lookin out.
  11. #11 Re: oil level low
    West Central Ohio
    Thread sealant is a thick substance that usually comes in a can. You can get it at the auto parts store. It usually has a threaded cap with a brush attached to it, just paint some on the threads before you screw them in. You don't need a massive amount on there, just enough to fill the threads.
    I have a similar problem. I have 3500 miles on my car since I bought it, 23k total. It's a 2005. The low oil level warning came on the other day. I checked the dipstick and in fact it was low. Put a quart in and the level was good. I am not real happy this thing burns oil with 23k miles on it. I had a 1994 GP and it became a fill the oil and check the gas routine. A quart every 500. Any ideas on this one fellas? It's definitely not leaking it onto my garage floor.
    I'm guessing GM will say that a quart every 3k is within spec. Then they'll remind me I'm out of warranty.
  12. #12 Re: oil level low
    Barksdale AFB, LA
    Mine was leaking it internally onto the LIM, as you can see here:
    http://img.photobucket.com/albums/v3...f/DSC03335.jpg
    It was probably also being burned. I also burned a little oil when I used a PCV valve of a brand other than AC Delco. The AC Delco was cheaper than the Auto Zone brand anyway... Just some suggestions.
  13. #13 Re: oil level low
    May 2008
    Chicago(southside)
    i hope it isn't from worn guides .i just noticed im down a qt.thanx for the info buckeye
  1. Finally no longer SE Level!!
    By GeddyLee in forum Off Topic Discussion
    Last Post: 04-30-2010, 09:47 AM
  2. trans fluid level
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-13-2008, 02:45 PM
  3. GTP Level member
    By IndeedSS in forum Off Topic Discussion
    Last Post: 03-10-2008, 10:16 PM
  4. What Entry Level Struts?
    By RNUOVR in forum Brakes/Suspension/Chassis
    Last Post: 01-15-2008, 09:07 AM
  5. Oil Level Sender Thread
    By Speeder in forum Turbo
    Last Post: 01-08-2008, 09:25 PM
