Thread: Chug at start, "bouncing" tach when key turned to "on"...
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #21 Re: Chug at start, "bouncing" tach when key turned to "on"...
    Donating Users zildjian102's Avatar
    Wilkes Barre, PA
    just found this thread. My tach does the same thing when i turn the key to the on position. it does that little bounce thing buy my car runs fine there is nothing wrong with it so idk
    2002 Grand Prix GT- top swap soon
    1997 Pontiac Grand Prix GTP-project/parts
    3.4 pulley, intense tune, SD headers, intake, 180 tstat, al104's
  2. #22 Re: Chug at start, "bouncing" tach when key turned to "on"...
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    Quote Originally Posted by SlowNA06 View Post
    See what your EGR is doing at idle. This strikes me as a vacuum leak, though, so check all your connections.
    Also, try unplugging the MAF and seeing if it runs better.
    vac leak should have coded an o2 for lean mixture.
  1. "2nd gear start"
    By bjhartogh in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 06-09-2016, 01:49 PM
  2. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  3. "97" 4t65e-hd succesfully installed replacing the "00" 4t65e-hd
    By mikedinthecity in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-06-2009, 01:42 PM
  4. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
