Thread: Now that the engine is out....
Results 1 to 6 of 6
  1. #1 Now that the engine is out....
    SE Level Member JoeMama's Avatar
    Houston, TX
    Now that i've got the engine out, i plan to:
    1) Replace powersteering pump
    2) replace coolant hoses
    3) replace spark plugs and plug cables
    4) Fix tranny and replace torque converter
    5) Replace serpentine belt
    6) Replace engine oil pan gasket (I think there was a bulletin about this a few years ago)
    7) ??
    Is there any other maintenance stuff I should be doing?
    I want to do the least amount of work possible on the engine, since it was pretty good when I removed it, and I want to do as much maintenance as possible without spending a lot of cash. Also, if I can do any cheap mods (like less than $100-$200) if it will help with MPG, I will probably pursue it. The car is completely stock right now.
    Any suggestions are appreciated.
  2. #2 Re: Now that the engine is out....
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    water pump
    coolant elbows
  3. #3 Re: Now that the engine is out....
    Oklahoma
    Probably the timing chain while its out. The rear knock sensor is pretty hard to get to so I would probably replace that for good measure. Replace the lower motor mount and tranny mount.
  4. #4 Re: Now that the engine is out....
    Houston, TX
    Yikes timing chain really?
    Also, why coolant elbows?
    Water pump is probably a good ideas.
    How much would a knock sensor be, and where is it located?
  5. #5 Re: Now that the engine is out....
    Barksdale AFB, LA
    Quote Originally Posted by JoeMama View Post
    They tend to go bad for no reason. Then you gotta take the tensioner off while its still in the car.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Now that the engine is out....
    Oklahoma
    Timing chain shouldnt be that big of a deal. The knock sensor (rear one) is going to be about the middle of the head (#5 cylinder), on the block I believe. Its got a connector on it with one wire. You should be able to get them from Autozone and I think they were around $30 or so.
  1. Which engine oil?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-11-2008, 04:41 PM
  2. Engine???
    By duane9586 in forum General Tech Discussion
    Last Post: 05-10-2008, 09:46 AM
  3. engine worries
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2008, 08:34 PM
  4. engine issues ??
    By sal3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-10-2008, 06:24 PM
