Thread: Hissing noise, is it the fuel pump?
Results 1 to 10 of 10
  1. #1 Hissing noise, is it the fuel pump?
    south florida
    Hey guys I've noticed a somewhat loud hissing noise coming from the rear underneath part of my 97 gp gt. It definitely louder on the drivers side and I almost thought that one of my tires was leaking haha. Is it most likely time for a new fuel pump for me? I know its weak because I leave in my key on for a couple seconds before starting so the fuel pressure can reach the engine. I just wanted to know what you guys think? Thanks a bunch.
  2. #2 Re: Hissing noise, is it the fuel pump?
    Kansas
    Sounds like an exhaust leak.
  3. #3 Re: Hissing noise, is it the fuel pump?
    south florida
    No its not that because when I just turn my key on w/o engine i hear the noise for a second I just want to know if I need to actually REPLACE the fuel pump or is this noise normal or what?
  4. #4 Re: Hissing noise, is it the fuel pump?
    Noisy fuel pumps are a standard GM feature. Likely it's what you hear. Doesn't really mean anything though. What means more is that you already know you have a pump issue and you'd like us to say it's time to change out the pump.
    Being a nice guy, I'm going to suggest you check out TREPerformance.com for a pump. I've used them for a high flow in the Bonneville, a regular pump in my truck and Regal will be getting one when I get off my lazy butt. Prices are tough to beat and I've put a healthy 3+ years of testing into their pumps.
  5. #5 Re: Hissing noise, is it the fuel pump?
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    All of my fuel pumps make a hissing noise. I thought that was just the sound of them running
    silver 2003 Grand Prix GT List is on it's way to be updated
  6. #6 Re: Hissing noise, is it the fuel pump?
    south florida
    Okay thanks ill check it out. Stll wondering though how "bad" i need a new fuel pump and what not ..
  7. #7 Re: Hissing noise, is it the fuel pump?
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Check fuel pressure.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  8. #8 Re: Hissing noise, is it the fuel pump?
    Apr 2012
    Peoria, Arizona, United States
    Well i have a 2000 Pontiac Grand Prix 3.8 GT and i just recently heard a hissing noise near fuel tank, Chevy told me thats just how they are. Fuel pressure was good and i didnt have to worry. but, ive changed fuel filter, replaced rear exhaust manifold gasket and welded cuz it had crack, flange gasket, water pump, thermostat, spark plugs, wires, now car runs great. i still think i have bad gas miliage and idk why. but when ac is on for a long period of time, temp stays up above 210 around 245 or so and that seems too hot for the car. coolent level isnt low. it doesnt do this when ac is off. anyone know why???
  9. #9 Re: Hissing noise, is it the fuel pump?
    Yes, that would be that the fans are factory programmed to come on at 216F and 228F.
  10. #10 Re: Hissing noise, is it the fuel pump?
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by Slrmclaren2006 View Post
    Make sure both fans are on when AC is on. Turn the AC on and pop the hood.
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  3. Hissing Noise On A 1999 Pontiac Grand Prix
    By GrandPrixChic in forum General Tech Discussion
    Last Post: 12-24-2010, 02:00 AM
  4. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
