Thread: white smoke.
Results 1 to 11 of 11
  1. #1 white smoke.
    Jul 2008
    sumter,south carolina
    so the gp i bought last night threw a CEL today.. i get home and im sitting in teh driveway @idle for 5 minutes or so.. i look in my mirror and see white smoke pouring out of the exhaust. i shut it down and let it sit for a minute. cranked the car back up and i have some pretty serious top end noise.. still dont know the code yet... but the car is under warranty and getting fixed for free.. kinda sounds like a bent valve maybe. oil doesnt look contaminated at all. however i popped my oil cap off and took a whiff and it smells strongly like gas. my first thought is o2 took a serious **** and filled cylinders up with gas. what do u guys think.
    02 GTP with mods 05 GP for DD
  2. #2 Re: white smoke.
    Charles City, IA
    White smoke=coolant.
    SMGPFC Two Nipple General
  3. #3 Re: white smoke.
    Jul 2008
    hmmm... oil or smoke dont smell like coolant.. stuck my nose in oil filler cap and it smells strongly of gas.
  4. #4 Re: white smoke.
    St. Louis
    Almost sounds like an injector got hung open and just kept filling a cylinder with fuel. Not sure this is common on the GP's, but I've seen other makes have this issue when the ECU takes a dump.
    Top end noise could just be the fuel washing everything down since you said you can smell it in the oil. Def. need 2 oil changes and then see what you get. Hopefully the damage was minimal.
  5. #5 Re: white smoke.
    Jul 2008
    ohhhhh no... i posted in wrong section... im N/A in teh new ride.
  6. #6 Re: white smoke.
  7. #7 Re: white smoke.
    Intake gaskets took a crap?
    Which is odd...since they are the revised ones.
  8. #8 Re: white smoke.
    Jul 2008
    i would have never known from driving it, but the cat was clogged. i guess sitting at idle for as long as i did with no air movement under the car to cool it off.. it started burning **** in the cat? thats the only explanation for the smoke that can i figure out.. intake gasket is fine.
  9. #9 Re: white smoke.
    So that was the issue huh.
    Word.
  10. #10 Re: white smoke.
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    wat year is the new GP
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  11. #11 Re: white smoke.
    Jul 2008
    Its an 05.
  1. White smoke
    By dhaller in forum General Tech Discussion
    Last Post: 04-14-2010, 08:13 PM
  2. White smoke
    Last Post: 04-10-2010, 06:29 PM
  3. Jerking and white smoke
    By jhnath in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-01-2009, 12:51 AM
  4. White smoke problem
    By SilverGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2009, 10:24 AM
  5. SES light/White smoke
    By fudhimself in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-29-2009, 10:30 PM
