Thread: 139k on '04 top swap-able?
Results 1 to 10 of 10
  1. #1 139k on '04 top swap-able?
    Indianapolis
    So like the title says I have a 2004 GP with 139k on it. Would it be a bad idea to do a top swap on it. Or should I get an engine from a scrap yard and then build off of that?
    I asked my uncle and he talked to his coworker about it who works on cars and that guy said it would be like telling an 80 year old to go run a marathon and I would blow up the engine but I wanna get opinions from GP owners
  2. #2 Re: 139k on '04 top swap-able?
    Charles City, IA
    It would be fine.
    SMGPFC Two Nipple General
  3. #3 Re: 139k on '04 top swap-able?
    Troy OH
    i bet it would be ok. you'll replace the top end, so the only thing you'll have to worry about are pistons (which are bulletproof if you tune it right) and rod/main bearings. 139k isn't that high
  4. #4 Re: 139k on '04 top swap-able?
    New Jersey
    Quote Originally Posted by Poil336 View Post
    Pistons, and rings which have been worn in under certain conditions and exceeding / changing them may drastically accelerate wear.
    Personally I wouldn't do it. However, I believe there have been many here that have top swapped high mileage engines successfully.
    Also keep your transmission in the back of your head during this.
  5. #5 Re: 139k on '04 top swap-able?
    It'd cost more but you could get a low mileage L26 and build it on a stand.
    Even put a mild cam in there.
  6. #6 Re: 139k on '04 top swap-able?
    I cammed my L67 at 186K. If it's running good, don't worry.
  7. #7 Re: 139k on '04 top swap-able?
    Indianapolis
    Thanks guys, I think Im gonna go for it since it runs good and if something does end up happening to the tranny in the long run I have someone that can rebuild it for pretty cheap
  8. #8 Re: 139k on '04 top swap-able?
    Jersey
    my gt bottom end has 149k
    16' wrx sti- stock
  9. #9 Re: 139k on '04 top swap-able?
    Donating User Odi's Avatar
    Chicago South Suburbs
    there was a built 200k mile engine that ran low 12's. i dont recall who had it. if your engine is maintained, before and after the swap, itll be fine.
  10. #10 Re: 139k on '04 top swap-able?
    i swapped my car at 108k miles and cammed it. it loved it.
  1. Tranny filter clogged 100% at 139k
    By Blue00GTcoupe in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-28-2011, 11:47 PM
  2. v8 swap
    By Dalby46 in forum Introductions/Noob Questions
    Last Post: 07-21-2010, 08:02 PM
  3. i might top swap
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-02-2010, 12:15 AM
  4. top swap
    By jrgoleman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-22-2009, 04:24 PM
