Thread: water in oil filler neck
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: water in oil filler neck
    Michigan
    lol, my only way to get to work is this car! I just would like to hear what other possibilities it is if its not the intake gaskets!
  2. #22 Re: water in oil filler neck
    New Jersey
    Quote Originally Posted by m1sterb0b View Post
    Water in crank case possible causes?
    Cracked block, cracked head, cracked intake, bad headgasket, bad intake gasket.
  3. #23 Re: water in oil filler neck
    take it apart and figure it out. we dont have 500 mile range x-ray vision.
  4. #24 Re: water in oil filler neck
    GT Level Member donmega's Avatar
    St louis, mo
    is it the intake manifold its self? plastic has a tendancy to corrode from dexcool common problem. causes anitfreeze in oil replace it and use ethynol glycol the green
    "well we can spend 1000s throwing parts in it and hope that fixes the problem or we can diag it correctly and change the .50 cent fuse...lets ask the owner what he wants to do" --Walt R.--
  5. #25 Re: water in oil filler neck
    Grand Rapids, MI
    Quote Originally Posted by donmega View Post
    this is true, might just need to replace your plenum. when you take it off, you'll see you LIM. if it has water sitting there, there's your problem.
    and yes, replace with ethylene glycol (correction, haha)
  6. #26 Re: water in oil filler neck
    Michigan
    when we replaced the upper intake gasket and the lower intake gasket, there was no antifreeze pooled on the intake manifold! the owner of the care before me had already had the upper intake gasket replaced and the plenum replaced with a high heat plastic plenum!
    And bio, I know you don't have 500 mile x-ray! :P even though you should! I Just wanted to know what the other possibilities were so I could look into them seeing as we already replaced the intake gaskets (and yes the lower intake gasket was replaced with the new updated one with the aluminum frame!)
  7. #27 Re: water in oil filler neck
    New Jersey
    New gaskets can leak, mistakes happen.
    Besides your going to have to pull the intake to do the head gaskets anyway if need be. So get to work. Chances are your going to pull the intake and see the leak immediately.
    Or wait and keep driving it until you have completely destroyed the engine which you may have already.
  8. #28 Re: water in oil filler neck
    Michigan
    Well, took an extensive look at my car today! It almost over heated last night on the way home on a 70 mile drive, 5 miles into it! :P
    So I decided to take time to actually look at it today, and we got a fresh thing on snow last night so I could see if it is leaking externally. Another thing that made me decide to check it again is last night when I stopped to meijer to get antifreeze to put in it, I checked the oil to see how it was and it was NOT even slightly milky and with how much it leaked and for the oil to not be milky, and it was actually a quart low, which I gotta figure out where THAT is leaking out, I figured it wasn't leaking into the oil and if it was it wasn't a quick leak it was a VERY slow leak, not fast enough for my car to get as low as it did. It took about 3/4 of a gallon, put the rest in the overflow and it took that up as well when it cooled down. Checked into it and the elbow from the tensioner to the intake manifold was leaking pretty good, enough to melt a 4 inch circle in the snow, I'd say while running it for 10 minutes it leaked about half a cup to a cup of antifreeze just from that. So imma replace that and do a pressure check to see whats going on from there! My dad looked at the condensation in the oil filler neck and said that it was normal levels for winter! donno bout it but that's what he says and he's been workin with 3.8's for 20 some odd years!
  9. #29 Re: water in oil filler neck
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    If you do a lot of city driving, stop and go, or short trip driving, you can expect a good amount of milky oil to build up on the bottom side of the oil filler cap.
    Once you get the newly discovered coolant leak fixed, take it for a good long highway trip, to get the engine hot enough, for long enough, to help evaporate the condensation or moisture that has formed in the oil, IF your that worried about it. In all honesty, its not something to be concerned with.
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  10. #30 Re: water in oil filler neck
    Michigan
    I don't do a lot of city driving, the majority of my driving is 30+ miles at a time! part of it IS city driving, but not stop and go enough to do much, and by the time I'm there engine is fully warmed up! but my dad still says that it can happen, especially in the colder temps!
  1. water in heater blower fan or water on passanger floor
    By coolcat2010 in forum How To Write-Ups/Tech Tips
    Last Post: 03-19-2010, 04:20 PM
  2. Hole filler / patching up
    By KawaFord in forum Off Topic Discussion
    Last Post: 09-01-2009, 08:28 PM
  3. Neck Problems?
    By Darkcelle in forum Off Topic Discussion
    Last Post: 05-15-2008, 11:24 AM
  4. License Plate Filler
    By Berger in forum Visual/Body Modifications
    Last Post: 03-02-2008, 09:37 PM
