Thread: Replacing ignition switch, can't pull lock cylinder
Results 1 to 2 of 2
  1. #1 Replacing ignition switch, can't pull lock cylinder
    Nov 2010
    Nashville TN
    Hi folks,
    I am trying to replace the ignition switch on my 2000 regal ls. I have some trouble to release the lock wheel cyliner. I followed the service manual and several online writeup. But when I put a allen wrench on the hole of electric lock module, I can't push the hex key any further down to release the retaining pin.
    Did I do something wrong or the retaining pin on my cyliner lock is frozen? If the latter, what should I do?
  2. #2 Re: Replacing ignition switch, can't pull lock cylinder
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    try to rotate/wiggle the cylinder while pulling out as you have the release pressed.
    97 GT - slow, rusty
    93 CTD - more slow, less rust
  1. Key stuck in ignition lock cylinder
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 01-17-2019, 10:47 AM
  2. ignition switch cylinder
    By mtz956 in forum General Tech Discussion
    Last Post: 08-29-2010, 02:21 AM
  3. Replacing lock cylinder?
    By scottm in forum General Tech Discussion
    Last Post: 07-13-2010, 05:37 PM
  4. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  5. 911, Help Im locked in my car... Oh, pull lock? um Thanks!
    By FoSHO99 in forum Off Topic Discussion
    Last Post: 04-01-2009, 11:07 PM
