Thread: HVAC Control Module
Results 1 to 3 of 3
  1. #1 HVAC Control Module
    Pennsylvania
    My HVAC control box needs replaced, I believe. The knobs for fan speed, direction, and heat level work fine, but the buttons for the AC and Rear Defrost barely work. It takes me sitting there pushing the button for 5-10 minutes repeatedly to get either one to work. The middle button for recirculation works fine.
    So being that winter is upon us, Im going to need my rear defrost to work. Can anyone give me an estimate on the cost of this part? Or if it's even available anywhere? I've looked around at some stores and cant find any. Might end up having to take a drive to the junk yard.
    Or... if there's an easier way to fix this than replacing the whole box, that'd be cool.
    '08 Base btw.
  2. #2 Re: HVAC Control Module
    Charles City, IA
    Go to the junk yard and get the whole control panel. Pop your dash trim off and replace it. Should be very easy for you to do yourself.
    SMGPFC Two Nipple General
  3. #3 Re: HVAC Control Module
    SE Level Member trickytransam's Avatar
    Michigan
    Yep, this might help car-part.com
    Pick HVAC Controls, Pick what part of PA you live in
    Pick your options
    man cont (opt C67), non heated seat
    auto/aux cont (opt CJ2), heated seat (opt KA1)
    auto/aux cont (opt CJ2), non heated seat
    man cont (opt C67), heated seat (opt KA1)
    Search. It'll bring up many of the local boneyards in your area to pick from as a starting point.
    Not all are in the database, but gives you a good idea of the going rates.
  1. lost hvac control 97 3.8
    By Onthebrinc in forum General Tech Discussion
    Last Post: 02-28-2009, 03:49 PM
  2. HVAC Control Switch
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-31-2008, 07:34 AM
  3. No hvac control
    Last Post: 03-23-2008, 03:24 PM
  4. hvac control
    By Chleby in forum General Tech Discussion
    Last Post: 01-17-2008, 11:53 AM
