Thread: Washer Fluid Low Light always on
Results 1 to 2 of 2
  1. #1 Washer Fluid Low Light always on
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    I have a 1997 SE with the 3800NA engine. I just completed changing the water pump, thermostat, belt and upper and lower radiator hoses. In the process, got rid of the DEX(). I know it is probably a coincidence, but now my windshield washer fluid low light in my analog DIC stays on. The WW fluid reservoir is as full as it gets. I didn't see any fuses for it. Could the sensor have gone bad? If so, do I have to swap out the whole reservoir to change it or is there a way to pop it out that I am missing? If not, where else can I check?
  2. #2 Re: Washer Fluid Low Light always on
    Charles City, IA
    The sensor is probably bad, try just unplugging the sensor and the light should go out.
    SMGPFC Two Nipple General
  1. washer fluid pump
    By thewaitinggame in forum General Tech Discussion
    Last Post: 04-26-2011, 08:17 PM
  2. Windshield washer fluid
    By flyboyray1 in forum General Tech Discussion
    Last Post: 03-18-2010, 10:07 PM
  3. Low Washer Fluid
    By ericrluoma in forum General Tech Discussion
    Last Post: 09-17-2009, 11:11 PM
  4. Windshield Washer Fluid
    By Pontiac99GTP in forum General Tech Discussion
    Last Post: 09-09-2009, 01:35 AM
  5. Washer Fluid Injection
    By 98GT3800 in forum General Tech Discussion
    Last Post: 10-21-2008, 11:51 AM
