Thread: Open Cone Intake
Results 1 to 10 of 10
  1. #1 Open Cone Intake
    Nov 2010
    Indiana
    I have seen plenty of write ups on how to make Fenderwall intakes, but how do you make an open cone intake? I read a post where someone said "put a cone filter on the end of the MAF housing and call it good." is that the same thing as an open cone intake? REgardless, how do you make an Open cone Intake?
  2. #2 Re: Open Cone Intake
    Florida
    Yes, that is an open cone.But honestlopen cones suit supercharged cars better.If you're naturallyaspirated then yuo want cooler air so just make your own or spend a few hundo on an aftermarket setup.
  3. #3 Re: Open Cone Intake
    Nov 2010
    Indiana
    Quote Originally Posted by dmahlikGT View Post
    Thanks. is this a good do it yourself intake for naturally aspirated engines? http://www.grandprixforums.net/simpl...res-33351.html
    Or would you reccommend this one? http://www.grandprixforums.net/fwi.php
  4. #4 Re: Open Cone Intake
    4" piping or bust
    One bend at thats it.
    I wouldnt put it in the fender. too much water gets in there.
  5. #5 Re: Open Cone Intake
    Nov 2010
    Indiana
    4" piping or bust
    ??? 4" piping or bust... what do you mean? so use the first example then?
  6. #6 Re: Open Cone Intake
    Florida
    Yes that simple intake is your best bet.Thats what im doing lol.Its easy,cheap,effective, and yea you'll like it.
  7. #7 Re: Open Cone Intake
    Nov 2010
    Farmington, MN
    I just pulled out the air filter box and left the bottom "pan" in place. I attached a cone filter to the end of the stock [flexible] intake tube (pipe?). There is abut 1/2 inch lip where the stock airbox bolted to the end of the intake tube. That was plenty to attach the [cheap] cone filter. The flexible intake tube allows the filter to rest in the pan of the air filter box. Couldn't be any easier. Took all of 20 minutes. Inexpensive also, not too much more for a KN cone filter. I get a bit more intake sound, which I like.
    My .02 worth, from a noob ,
    ominousone
  8. #8 Re: Open Cone Intake
    the corrugated hose is one of the restrictive parts in the intake, get rid of it.
  9. #9 Re: Open Cone Intake
    K&N's suck.
    Get a Spectre. Best filter I've had to date. Buy one and Autozone...and get the BIG one. Pretty sure they are $39.99. Like Canada man said...4" tubing...and you want the filter to rest close to the hole in the fender...not really IN IT.
  10. #10 Re: Open Cone Intake
    Nov 2010
    Farmington, MN
    I agree. I was just going the easiest and quickest route. Eventually, I will look into a better intake pipe. The cone filter I have is the Spectre from O'Reilly.
    Later,
    ominousone
  1. Dyno Science: "CAI" Box vs Open Cone Intake
    By SlowNA06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2016, 12:29 PM
  2. FWI vs Open cone
    By lflylow in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-01-2010, 10:26 PM
  3. Open cone intake
    By GMCARS4LIFE in forum General Tech Discussion
    Last Post: 08-11-2010, 05:01 PM
  4. open cone
    By CompCam21 in forum General Tech Discussion
    Last Post: 06-05-2010, 09:39 PM
