there is a tube that comes out of the top of my engine and goes into the large round black thing on the fire wall (drivers side). it is loose where it goes into the engine. any1 know what this is? thank you
15/16ths PCV hose from parts store.
get two feet of it, trim it to fit and replace that hose if thats what you're concerned about.
The line is for vacuum to the brake booster.
Which is what gives you power brakes.
Annnnddd...will give you just a LITTLE vacuum leak...ya.
We know what it is...its the brake booster line. If its cracked, replace it.
I dont know how that fitting attaches, never seen an L26 brake booster line.
If you have a '04+...then its a L26.
so uh, where are the pics?
to make them more snug the easiest thing to do is buy new lines.
here r the pics. its not the hose thats loose. its the piece it goes on. and i also notices there is a sensor above each piston ( i pointed the out in the 2 of the pics) that has the same type of elbow joint. they are all loose as in they turn and wiggle. hope the pics help man...
hose pictures by ducatidrew - Photobucket
i think its a rubber seal, but i could be wrong. Maybe go to the local parts store and ask. I dont have access to alldata right now, so i dont know for sure
the injectors can move all they like as long as the gas doesnt get out.
