Thread: need ur help!!! regarding a tube coming out of the engine.
Results 1 to 20 of 22
  1. #1 need ur help!!! regarding a tube coming out of the engine.
    Donating Users drewprix86's Avatar
    ATX
    there is a tube that comes out of the top of my engine and goes into the large round black thing on the fire wall (drivers side). it is loose where it goes into the engine. any1 know what this is? thank you
  2. #2 Re: need ur help!!! regarding a tube coming out of the engine.
    15/16ths PCV hose from parts store.
    get two feet of it, trim it to fit and replace that hose if thats what you're concerned about.
    The line is for vacuum to the brake booster.
    Which is what gives you power brakes.
  3. #3 Re: need ur help!!! regarding a tube coming out of the engine.
    Annnnddd...will give you just a LITTLE vacuum leak...ya.
  4. #4 Re: need ur help!!! regarding a tube coming out of the engine.
    ATX
    the tube is tight. its the connector for\\rom the block to the hose thats loose and wiggles and goes in and out. ( not all the way out though thank goodness
  5. #5 Re: need ur help!!! regarding a tube coming out of the engine.
    We know what it is...its the brake booster line. If its cracked, replace it.
  6. #6 Re: need ur help!!! regarding a tube coming out of the engine.
    I dont know how that fitting attaches, never seen an L26 brake booster line.
  7. #7 Re: need ur help!!! regarding a tube coming out of the engine.
    ATX
    i think its a l36 . i dunno. whats the diff?
  8. #8 Re: need ur help!!! regarding a tube coming out of the engine.
    If you have a '04+...then its a L26.
  9. #9 Re: need ur help!!! regarding a tube coming out of the engine.
    ATX
    got the pics. also there r 2 extra pics of these connectors that have a loose elbow joint too. all six of them. how to make them more snug?
  10. #10 Re: need ur help!!! regarding a tube coming out of the engine.
    so uh, where are the pics?
    to make them more snug the easiest thing to do is buy new lines.
  11. #11 Re: need ur help!!! regarding a tube coming out of the engine.
    ATX
    here r the pics. its not the hose thats loose. its the piece it goes on. and i also notices there is a sensor above each piston ( i pointed the out in the 2 of the pics) that has the same type of elbow joint. they are all loose as in they turn and wiggle. hope the pics help man...
    hose pictures by ducatidrew - Photobucket
  12. #12 Re: need ur help!!! regarding a tube coming out of the engine.
    Jul 2008
    sumter,south carolina
    u mean ur injectors?
    02 GTP with mods 05 GP for DD
  13. #13 Re: need ur help!!! regarding a tube coming out of the engine.
    the senosr looking things are fuel injectors, and the piece where the hose go's on can be replaced if needed.
  14. #14 Re: need ur help!!! regarding a tube coming out of the engine.
    ATX
    ok. does it need any thing to seal it to the blower? ie glue , grease. ect/
  15. #15 Re: need ur help!!! regarding a tube coming out of the engine.
    i think its a rubber seal, but i could be wrong. Maybe go to the local parts store and ask. I dont have access to alldata right now, so i dont know for sure
  16. #16 Re: need ur help!!! regarding a tube coming out of the engine.
    the injectors can move all they like as long as the gas doesnt get out.
  17. #17 Re: need ur help!!! regarding a tube coming out of the engine.
    Portland Oregon
    Quote Originally Posted by drewprix86 View Post
    Blower? You're normally aspirated bud...
  18. #18 Re: need ur help!!! regarding a tube coming out of the engine.
    ATX
    somebody else called it a blower. lol i just went with it. whats it called? the very top part?
  19. #19 Re: need ur help!!! regarding a tube coming out of the engine.
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    N/A= Intake Manifold
  20. #20 Re: need ur help!!! regarding a tube coming out of the engine.
    ATX
    holy ****!!! u should let me have that thing. ill give u like $5. u have a pay pal? lol
  1. Replies: 13
    Last Post: 04-12-2010, 08:45 PM
  2. Weird noise coming from my engine bay *with video's*
    By nawarkk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2010, 01:32 AM
  3. Engine overheats, heater blows cool air, leak by egr tube
    By twillroth in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-30-2009, 03:13 PM
  4. weird noise coming from engine
    By q1w2e3r4t5 in forum General Tech Discussion
    Last Post: 04-02-2009, 09:59 PM
  5. Grinding noise coming from my engine
    By zeppelinrocks18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 04:24 PM
