like it says.. Every time i start this car it has very extended crank, when it does turnover it will not idle unless i keep it running myself. I have been trying to figure this out, any help would be appreciated. I have replaced the coil packs, new plugs, plug wires, fuel pressure reg, and map sensor. It has not resolved this issue. I did pull a vac hose and it does idle and runs great, but soon as i put the hose back on, the car dies instantly. Unplugging the IAC does not make a difference.
