Thread: Terrible MPG.. Any suggestions?
Results 1 to 20 of 26
  1. #1 Terrible MPG.. Any suggestions?
    SE Level Member ddrum's Avatar
    Bartlett, IL
    -I have a 2002 GP GT and its getting 13.3 MPG
    -The only thing ive done to the car to affect fuel economy
    would be my rims. They are 17's with 2 inches of rubber. I know I wont get alot with those, but i would think it would be higher than 13.3 . Every 3 mile trip the fuel meter goes down a nick.
    -To filter out 50% of everybodys first answers, no I dont go WOT at every light. I do drive "economically"
    -I do mostly city driving
    -have new air filter, and other regular maintnence
  2. #2 Re: Terrible MPG.. Any suggestions?
    Kansas
    are you getting 13.3 according to the DIC?
    SOLD 1999 GT Silvermist TS
  3. #3 Re: Terrible MPG.. Any suggestions?
    Bartlett, IL
    Yes. I reset it when i put the rims on about a month ago.
    I know people who run 20's and get better gas milage.
    im puzzled
  4. #4 Re: Terrible MPG.. Any suggestions?
    Apr 2009
    stockton ca
    My guess is tune up time and maybe o2 sensor time
  5. #5 Re: Terrible MPG.. Any suggestions?
    GTX Level Member cerick08GP's Avatar
    If you are really getting 13 mpg that is awful. Be aware that changing your rims ( wheel OD) will change the DIC reading without properly adjusting the PCM.
    That being said, here is a list of tune up items.
    1) Front O2 sensor replacement
    2) Spark plug replacement
    3) MAF cleaning
    4) Proper tire inflation (30psi bare minimum, I personally recommend about 34 psi when checking a warm tire)
    If you address these areas without a change, the problem becomes a lot harder to find. Because then it could be any of a long list of insidious problems.
    Good luck
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  6. #6 Re: Terrible MPG.. Any suggestions?
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    ^that and clean up your injectors too.
    97 GT - slow, rusty
    93 CTD - more slow, less rust
  7. #7 Re: Terrible MPG.. Any suggestions?
    Minnesota
    Im getting horrible mileage to, its down to like 11.6! I tried changing my plugs,maf,font o2 and its still bad. Are you running no cat? I dono if that could have anything to do with it because its after the front o2, but I finally just threw the code for it.
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  8. #8 Re: Terrible MPG.. Any suggestions?
    Quote Originally Posted by Ricky21 View Post
    Just a SWAG but I’d bet your problem is your spark plugs. For optimal mpg you need to run stock heat range spark plugs and T-stat. If you’re running a smaller pulley you might want to try AL605s, otherwise stick to AL606s.
    2008GP
    2002GP||sold
  9. #9 Re: Terrible MPG.. Any suggestions?
    Minnesota
    I was thinking that, the reason I have 104s is because i plan on dropping pulleys soon and was under the impression that it wouldnt hurt for a short time
  10. #10 Re: Terrible MPG.. Any suggestions?
    I knew it
    In just going out on a limb here and am assuming you are a little mis-informed on spark plugs.
    IMHO many ppl believe colder and smaller gapped plugs some how make the engine run better or have more HP. The reality is the opposite is true; you want to run the warmest and widest gap plug you can. I’m not going it the complexities of this ATM (just to add this KR ya ya blah blah spark blow out yad yad). However, at 11mpg I’d go get a set of AL606s tonight. Recovering that 12 bucks won’t take very long, so why not just do it.
    2008GP
    2002GP||sold
  11. #11 Re: Terrible MPG.. Any suggestions?
    Minnesota
    So those will also run fine with a smaller pulley?
  12. #12 Re: Terrible MPG.. Any suggestions?
    I live here. TLSheff's Avatar
    Or you can just hold onto the plugs and put the 104s back in when you go with the smaller pulley
  13. #13 Re: Terrible MPG.. Any suggestions?
    Well, if you are going to run a smaller pulley soon I would install AL605s. They will only minimally affect your MPGs, and should allow a mild pulley drop. Every engine is different, so you’re going to want to monitor your KR just as you would for any pulley drop. But man why sweat it, plugs are cheap and easy to change. Definitely keep your 104s, but also definitely change to 606/605s for time being.
    2008GP
    2002GP||sold
  14. #14 Re: Terrible MPG.. Any suggestions?
    Minnesota
    Yea thats what Im thnking Im going pick some up right now its not like its hard to switch em out anyway thanks for the help
  15. #15 Re: Terrible MPG.. Any suggestions?
    Pennsylvania
    Quote Originally Posted by ddrum View Post
    So, this means you have a fresh fuel filter; fresh, appropriate spark plugs; a recently-cleaned and functioning MAF; clean throttle body; appropriate tire pressure; properly-functioning [read: not stuck] brakes; full, happy coolant; and happy transmission fluid with a functioning 4th gear.
    The only thing left would be... vacuum leak?
  16. #16 Re: Terrible MPG.. Any suggestions?
    SE Level Member Sinnoth's Avatar
    Waltham, MA
    The only thing I can think of is when I had a similar issue last year in my 2000 GTP. I had no idea why I was losing mpg's but it dropped to around 14-15 average without altering anything. Turned out my thermostat died and was constantly sending a too hot signal, forcing the water pump and fans to run continuously. Once I replaced the thermostat, my MPG's went back to normal.
    This was likely a unique problem, but it's worth checking.
    2000 Grand Prix GTP -stock-
    "Reality is the leading cause of stress."
  17. #17 Re: Terrible MPG.. Any suggestions?
    The water pump runs when the engine spins....
  18. #18 Re: Terrible MPG.. Any suggestions?
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    i have a 2000 pontiac and i had this problem.. about 12mpg and it was because my thermostat was broken and my car wouldnt heat up, and my CAT was clogged so i had to get a new one and my problems were solved
  19. #19 Re: Terrible MPG.. Any suggestions?
    SE Level Member Phantom's Avatar
    Independence KY
    With heavier rims and city driving that can badly hurt MPGs others might not get as bad of MPGs but they are doing a different drive than you. With heavier rims increasing speed is harder but maintaining speed is easy so in stop and go traffic they will hurt the most.
    You said that every 3mi trip the mpgs go down, if you are doing 3mi trips the car will not fully heat up and will use more fuel.
  20. #20 Re: Terrible MPG.. Any suggestions?
    Pennsylvania
    Quote Originally Posted by Phantom View Post
    This didn't make any sense. There's no excuse for a healthy NA 3800 to make 13mpg, ever. Something is broken.
  1. Terrible MPG
    By nFavor in forum 5.3L V8 (LS4)
    Last Post: 08-27-2012, 03:00 PM
  2. Terrible knock..need some help!!!!!
    By FooteGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2009, 11:57 AM
  3. Terrible Vibration.
    By 99LuminaLSC in forum Brakes/Suspension/Chassis
    Last Post: 12-31-2008, 10:46 AM
  4. Terrible Gas Mileage
    By TCO in forum General Tech Discussion
    Last Post: 12-16-2008, 01:01 AM
  5. CEL and terrible gas mileage
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 10-06-2008, 04:30 AM
