Thread: Junkyard top swap
Results 1 to 20 of 27
  1. #1 Junkyard top swap
    GT Level Member macey43's Avatar
    Jul 2010
    salisbury, MA
    Judging by the fact that it's pretty difficult to even find any grand prods in a junkyard I know this is a long shot. But if I had a miracle and were to locate a gtp with low enough miles that still had workng components.... Is it possible that I could get the parts for a top swap. I probably wouldn't even do it for a while it's just a thought in my head. But if I could find the parts and it is possible I might as well put together a kit and work from there. Let me know what you guys think if it's possible or if modified parts are needed. Also is it possible that I could take certain parts out of the HD tranny to do the HD upgrade to my non HD similar to the zzp kit. Thanks, mat
    sig too tall
  2. #2 Re: Junkyard top swap
    Outer Space
    there is a user or two on here selling a top swap... but Morad I think wants 600 bucks for a GUARANTEED set of parts.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: Junkyard top swap
    Jul 2010
    salisbury, MA
    Ya I know that would be a much better idea which eventually I might do but where I'm not really concentrating on it and I'm also 16 I'd rather not spend 600 haha. Thanks for the amazingly fast reply
    sig too tall
  4. #4 Re: Junkyard top swap
    Outer Space
    moradpartscompany.com ... they specialize in our cars... kinda like a catalog for you.
  5. #5 Re: Junkyard top swap
    Jul 2010
    salisbury, MA
    Quote Originally Posted by Lawngoose View Post
    Ok sounds like what I'll have to do. What about the tranny though?
    sig too tall
  6. #6 Re: Junkyard top swap
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Dont do burnouts while turning or long burnouts and the trans will be fine
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  7. #7 Re: Junkyard top swap
    Jul 2010
    salisbury, MA
    Ya I'm sure it will but if it was possible to upgrade for a reasonable price I might as well
    sig too tall
  8. #8 Re: Junkyard top swap
    Charles City, IA
    If you dont want to spend the $600 for parts, then dont top swap your car, it will cost you a lot more than that in the long run.
    SMGPFC Two Nipple General
  9. #9 Re: Junkyard top swap
    Jul 2010
    salisbury, MA
    are you saying it will cost more in the long run as if i go for cheap parts? or will it cost more in the long run no matter what?
    sig too tall
  10. #10 Re: Junkyard top swap
    if you put money into your motor, youll break other things. dont expect to top swap it and be done buying parts or fixing things.
  11. #11 Re: Junkyard top swap
    Jul 2010
    salisbury, MA
    ok so basically if i do it myself i will break other things and cost extra, if i take it to a shop it will cost something rediculous so either way it isnt gonna be like 300 bucks...
    sig too tall
  12. #12 Re: Junkyard top swap
    Jul 2010
    salisbury, MA
    oh ya and when you say break other things do you mean like as in the transmission? or other engine parts running it? or engine parts doing the swap?
    sig too tall
  13. #13 Re: Junkyard top swap
    Lets go down my list then...
    Top swap
    Led to headers
    led to welding them
    led to them cracking
    Now i need new headers
    S/C i bought needed needle bearings and a S/C coupler.
  14. #14 Re: Junkyard top swap
    Jul 2010
    salisbury, MA
    Hmm I think I might still be willing haha. I was actually considering headers first... As for the coupler and bearings that has to do with making sure I get a good one. How much were those anyway?
    sig too tall
  15. #15 Re: Junkyard top swap
    $40-50 shipped for the coupler ( canada)
    $10 for fluid that time,
    $10 for fluid the time I took it apart for the needle bearings.
    $60 shipped for the bearings, $20 for labour, $10 for TB gasket, $20 for S/C gasket, $2 for injector o-rings.
    Coupler is an easy check, turn the pulley one way then the other, if theres play then your coupler is in need of replacing.
    Bearings, if you move the thing and hear grinding.
  16. #16 Re: Junkyard top swap
    my route:
    top swap: spun bearing (my fault)
    new motor with top swap: plethora of parts that i bought to make the car fast
    parts to make car fast: demolished transmission
    new transmission: break transmission again
    broken transmission: sold car
    all in all, i spend around $12k+ on the car and made $1000 back when i sold it. have fun.
  17. #17 Re: Junkyard top swap
    Jul 2010
    salisbury, MA
    So I feel the only thing that really worries me is the tranny which I expected. That's why I was asking if I could just get the parts to upgrade to the HD
    sig too tall
  18. #18 Re: Junkyard top swap
    Willoughby, Ohio
    just have some extra money in case something does happen, and if you dnt beat on it every day not everything will break...if you add power to the car you add the risk of something breaking
  19. #19 Re: Junkyard top swap
    Jul 2010
    salisbury, MA
    Ok so if I do the regular top swap, correctly, then I should be fine other than my trans if I go WOT every second
    sig too tall
  20. #20 Re: Junkyard top swap
    its not that, its moreso epic downshifts and hammering the gas instead of rolling into it as well as burnouts and heavy throttle around corners.
    HD trans = hd differential which will still shred just as readily so just dont beat on it.
  1. junkyard tips
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-09-2010, 09:14 AM
  2. Junkyard Etiquette?
    By CSteen85 in forum Off Topic Discussion
    Last Post: 03-31-2010, 06:24 PM
  3. Trip to the Junkyard
    By stlmo_gtp in forum The Rant Forum
    Last Post: 07-20-2009, 05:05 PM
  4. Junkyard
    By rocafella2032 in forum Off Topic Discussion
    Last Post: 06-18-2009, 01:27 PM
  5. Junkyard Supercharger
    By gpgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-28-2009, 02:39 PM
