So I took my 03 in the other day for tires, and they went ahead and changed the oil. They reported to me that the pan had a major dent in it, which I assume must have been from road debris. Since I've owned it I don't remember snagging anything, so it had to have been there for a few years. Anyways, the gasket is leaking slightly anyways, so I'm going to need to pull the pan at some point.
I guess I'm wondering if I need to lift the motor at all to swap out the oil pan. If so, is there a way I can unbolt the pan and sneak a new gasket in between it and the oil pump?
They also told me there's a smaller dent in the tranny pan. Anything special to know there? I've never been under my 03, so I wanted to get informed before I do. I'm a little leery about changing the tranny pan. I always hear stories about cars with high mileage that do much worse with all new fluid.
