Thread: ZZP ER ratio rockers vs ZZP ST2 cam
Results 1 to 6 of 6
  1. #1 Re: ZZP ER ratio rockers vs ZZP ST2 cam
    Donating Users kfish's Avatar
    Ohio
    get the zzp er rockers and an hv3 insert.
    rockers are much easier than a cam...you just take the valve covers off and install them. cam involes taking the intake off, dropping the cradle etc.
  2. #2 Re: ZZP ER ratio rockers vs ZZP ST2 cam
    GT Level Member DBGP's Avatar
    Vancouver, BC, Canada
    I see, rockers it is then. Ive seen how to install rockers but never saw anything yet on how to install a cam. Rockers it is then! Yea i already got the hv3, along with overkill pcm tune, zzp dp w/ u bend delete, magnaflow mufflers, and k&n cai. Would the ER rockers be compatible if i get a turbo later down the road?
  1. Best Valve Springs for 1.9 Ratio Modified Rockers
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2010, 11:09 PM
  2. Installing 1.9 Ratio Modified Rockers
    Last Post: 02-08-2010, 10:50 PM
  3. what is my differential ratio, and first gear ratio?
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-07-2008, 09:31 AM
