Thread: Fuel Filter question
Results 1 to 13 of 13
  1. #1 Fuel Filter question
    Jun 2010
    altoona pa
    Can someone tell me where the fuel filter is located at?
    also i want to upgrade the plugs/wires
    does anyone have a recommendation on new ones
    thanks
  2. #2 Re: Fuel Filter question
    New Jersey
    The fuel filter is under the car next to the gas tank. Plugs.. if youre stock and plan on staying that way just get the Autlites from Autozone. Same thing with the wires unless you want to get the from the dealership.
  3. #3 Re: Fuel Filter question
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    do not try to turn the steel fuel line end itself, use a 5/8 ? line wrench to hold and turn the filter after you disconnect the other end, spray with penetrating oil a few days before you try to change it, disconnect the lines slowly and have a pan underneath it
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  4. #4 Re: Fuel Filter question
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by Madness View Post
    jesus christ dr safety!
    the filter is under the car on the drivers side, pretty much right "in front" of the rear wheel
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  5. #5 Re: Fuel Filter question
    Jun 2010
    altoona pa
    thanks appreciate it figured id ask before i got into it - learned from my mistakes on the jaguarforums.com
    as for the plugs i was thinking of going with something better than stock, any recommendations there?
  6. #6 Re: Fuel Filter question
    Charles City, IA
    Well what year is your car? mods? gt-gtp?
    SMGPFC Two Nipple General
  7. #7 Re: Fuel Filter question
    Jun 2010
    altoona pa
    04 v6 3.8 gt no mods
  8. #8 Re: Fuel Filter question
    Jun 2010
    altoona pa
    05*
  9. #9 Re: Fuel Filter question
    New Jersey
    i'm fairly certain an 05 is the same as my 06 and does not have a fuel filter.
  10. #10 Re: Fuel Filter question
    GT Level Member mezzoni's Avatar
    Nov 2009
    Milford, CT
    i changed my fuel filter in my 98 a couple days ago and had to bend the fuel line to get the filter off because the support clip was rusted onto the filter itself and i really had no other choice. no big deal tho just bent it back when i was done only moved it a couple inches no kinking or anything and its good as new now. however it seems like my mileage has gone down which doesnt make sense but im not all the way thru my tank yet so we'll find out...
    2006 pontiac G6 GT coupe - the daily
    2001 pontiac trans am WS6 - pacesetter headers, slp exhaust, diablo sport tuner, ported throttle body, ported MAF, SLP intake lid, B&M shifter, UMI panhard bar, lowered on koni's
  11. #11 Re: Fuel Filter question
    Mar 2016
    Louisiana
    I have no idea where my fuel filter on my 05 GP is located its not by the rear wheel O'Reillys gave me a metal canister filter and said if it was in the tank it would be call a nonservicable filter can someone help
  12. #12 Re: Fuel Filter question
    you dont have one, the sock on the pump is it.
  13. #13 Re: Fuel Filter question
    GXP Level Member
    Mar 2015
    Tomball
    ^^^^^^^^ what he said.
  1. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  2. Fuel Filter
    By newmarket23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-23-2009, 09:04 PM
  3. fuel filter.........
    By julian2875 in forum General Tech Discussion
    Last Post: 07-21-2009, 12:48 PM
  4. Fuel Filter question
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 03-26-2009, 09:20 PM
  5. S.O.B. Fuel Filter
    By quiksilvergt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2008, 01:16 PM
