Thread: Snapped some UIM gaskets, should I drive?
Results 1 to 8 of 8
  1. #1 Snapped some UIM gaskets bolts, should I drive?
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    I just replaced the UIM on my GP because of the leaks. Ugh, nice bit of oil in the intake. Anyway, while putting the UIM back on, I managed to snap two of the bolts. Right now, the front middle one and rear far left one are not in. Everything else is tight and secure. I went to a dealer today to try to get the bolts, but they said they'd have to order. I'd rather drive the car than my Imp, but with the bolts missing, am I chancing anything driving it? I can order the bolts Monday, and it'll be 3-4 days before I get them. I guess the only thing I am going to chance is a slight vacuum leak, but after putting everything back together, the car ran for a good 5 minutes without any problems.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  2. #2 Re: Snapped some UIM gaskets, should I drive?
    Barksdale AFB, LA
    Rear, left, as in driver side or passenger side? If it's the driver side (closest to the TB), I wouldn't drive it. Coolant into your intake would not be pretty...
    2009 Subaru Impreza WRX STI
  3. #3 Re: Snapped some UIM gaskets, should I drive?
    Hoffman/Schaumburg, IL
    Maybe you should change title so it says bolts
    Call Ed, maybe he can next day some to you
  4. #4 Re: Snapped some UIM gaskets, should I drive?
    Feb 2008
    Cumming GA
    Passenger side. When I removed the 10 bolts, it looked like there were approximately 3 different lengths/types. Two 10mm bolts also had screw threads on top for additional screws. One 8mm bolt was long; it was on the throttle body. The other seven appeared the same, but according to the picture at the dealer, there are four different lengths. That passsenger side rear one is shorter than the others.
  5. #5 Re: Snapped some UIM gaskets, should I drive?
    Saraland Alabama
    you will have a vaccuum leak at best, I wouldn't drive it much
  6. #6 Re: Snapped some UIM gaskets, should I drive?
    Feb 2008
    Cumming GA
    That's what I figured. I've got other vehicles, so I don't have to drive it for the handful of days it'll take to get the bolts. I can wait the day or two for the dealership. Probably will call early Monday morning, and maybe have the bolts by the afternoon on Tuesday.
  7. #7 Re: Snapped some UIM gaskets, should I drive?
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    How did you snap them off, IIRC they are torqued to like 11 ft lbs. There is a list of torques specs on this forum somewhere.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  8. #8 Re: Snapped some UIM gaskets, should I drive?
    Feb 2008
    Cumming GA
    Settings are 89 in lbs; we had them set to 84 in lbs. Snapped twice. I don't know if that's because it's the ZZP intake, or weak bolts. While the UIM was off, I noticed the lower intake gaskets were aluminum, so it's possible the car is now on its third upper intake. Or only the LIM was cleaned and gaskets replaced. It was pretty nasty inside the UIM; there was probalby a cup of oil sitting in it.
  1. Drive Belt Replacement [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 05-24-2009, 05:44 PM
  2. reuseable gaskets?
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-01-2008, 08:38 PM
  3. Finally got to drive my car today
    By Preotic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2008, 12:57 PM
  4. Head Gaskets...
    By newfie in forum Turbo
    Last Post: 01-18-2008, 12:31 AM
